Question about Exercise & Fitness
Treadclimber centering Treadles of the treadclimber woudn't center itself and lock. It keeps saying "please move treadles to the center"
  • ahmed Feb 21, 2012
    hi, your solution wasn't helpful. The treadles don't stay locked all the time. While working out, the treadles get slow and then go back to normal after awhile. Can you give me the number of a good service person or company to come and fix my treadclimber. My zip code is 60712, Lincolnwood,Il. Thank you.
    Top Expert:
  • 12,223 Answers
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 16, 2012
3 Suggested Answers
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
bugoy31
  • 1238 Answers
SOURCE: Assembled Bowflex Tread climber yesterday. Getting
Good day!
What is the model # of your Bowflex?
Posted on May 22, 2011
Bowflex treadclimber
yes you can do it. But only thing you have to remember is when ever you do it please remove the power from the ac out let. after making connection or disconnection just put back the power cable to ac outlet. keep the connection well insulated if you are going to make it as permanent. do not touch it while the treadmill is powered.
www.electro-medical.blogspot.com
Aug 22, 2015 | Bowflex Exercise & Fitness
TC20 treadles will not move after we disconnected pistons and then moved unit when we tried to reconnect pistons one treadles is too far down to comnect and will not move
The treadles can sort of overlap and one gets stuck on the other. Try to carefully grab the front of the one that is higher and pull it away from the other treadle, then it should be able to be lowered. If you have a second person they could pull the lower treadle in the opposite direction. Be careful not to pinch your fingers!
Apr 26, 2014 | Office Equipment & Supplies
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
Treadles only go uo and down about 3 inches. Hard to move them
These are fairly complex machines...call foe service 877-805-1030
Jan 03, 2014 | Bowflex TreadClimber TC5000
The treadles on my treadclimber are not rising and falling evenly. The treadle on the right seems ok, but the left treadle stays significantly lower. I have tried adjusting the dial to a lower number on...
Please RUN the software calibration for easy diagnostic and fix it.
go under the HOOD motor follow the steps, or read your owner manual /download from www. fitness.manualsonline.com
GOD BLESS YOU
Dec 02, 2013 | Bowflex Treadclimber
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
I have bowflex treadclimber tc5000, trouble is that when in use for climbing the right treadle moves off to the far right hitting side post on the way down. But it lines itself back up on the way up. I...
This is a common issue caused by a frequent assembly problem, made worse by the tools sent along with the TC for
assembly. To fix it, you need the following:
1. A GOOD 5/8" wrench (not the piece of junk that came with the TC).
2. A Phillips screwdriver at least 3" long.
3. Two books at least 1" thick.
4. One book about 3/8": thick, or two magazines
5. A vacuum cleaner with a hose.
6. The Treadclimber Manual. If you don't have it, get it online at the company's web-site.
Lock the treadles (see manual) such that the TC is just a treadmill.
Turn off the TC, unplug it, and remove the power cord.
Leaning the TC first left, then right, put the 1" books about 2/3 of the way towards the back under each side. This will left the rear of the machine slightly off the ground, making the following steps much easier.
Now use the Phillips screwdriver to remove three screws on each of the two rear-most plastic covers at the base of the machine. Remove the covers. Put the screws in the covers so you don't lose them. Note that the top screw is recessed deeply into a hole in the cover!
Removing the side covers has exposed 4 more Phillips screws that hold the back plastic cover in place. Remove them, and the cover will slip off (thanks to those two big books).
Everything is dusty dirty. Use the vacuum cleaner to clean it up. You'll thank me later when you don't sneeze your brains out.
Now, behind where the back plastic cover was, and across the back of the machine, are four big bolt-heads. These are the bolts that hold the tread assembly to the base of the machine. They're probably loose. If they're not loose already, use that wrench to loosen them a bit. Either way, things are out of whack.
Go around to the front of the machine. Use the small book or the magazines to wedge the right treadle away from the upright such that the treadles are evenly spaced between the two. Don't over-do it and reverse the problem! (This is a lot easier than yelling at your spouse or significant other to "hold it, hold it" while you complete the next step.) What you want is the two treadles nicely spaced between the front uprights. Trust me, the right treadle will hold that spacer.
Go back to the rear of the machine. Using the 5/8" wrench, tighten the four bolds VERY tight. Use some muscle. The fact that they were loose was the cause of the issue.
Now go to the front. Pull out the book/magazines that you were using as a spacer between the right treadle and the upright. Do the treadles look like they're now evenly spaced between the uprights? If so, pat yourself on the back. If not, then loosen the bolts and try again, adjusting the thickness of the front "spacer" as needed.
Put the rear cover back on. Don't over-do the tightness of the screws on this (or the other) cover(s)!
Put the left and right covers back on. Take care with these, they're a bit delicate, especially the top screws. If the little rubber posts fall out of the top screws, finesse them back in.
Don't forget to re-calibrate the machine (per that manual) after you finish.
You'll now discover in most cases that a lot of issues with uneven action are now cured. Any rub marks on the right upright can be removed with the same silicone spray that is recommended for the belts.
Enjoy.
Oct 01, 2010 | Bowflex Treadclimber
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
179 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
