Question about RTO Cybex 520T Remanufactured Treadmill
Cybex 520t treadmill runs for about 2 minutes then says end and quits running?
When I use my Cybex 520 treadmill it will run for about 2 minutes then it says end and the belt stops. I can start it again but it keeps doing the same thing?
  • Heath Postma Feb 18, 2012
    Did some more research, Cybex says not to lubricate there decks. Rotated the deck, problem solved. Thanks.
    Top Expert:
  • RTO Master
  • 12,223 Answers
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from NOT LUBRICANTING between the treadmill belt and deck.
This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Remember the treadmill is complex electronic system. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
see the block diagram that I design for easy diagnose and troubleshooting.
cybex 520t treadmill runs for about 2 minutes then - 2_16_2012_6_29_06_pm.gif
Posted on Feb 16, 2012
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: My Cybex 520T is comming up with Error 9 on the Screen
Hi, Error code 9 on your treadmill means the brushes on the motor need replacing. This is an automatic indication that is set for 100 miles of use to prevent damage to the motor. Replace both sets of brushes and this should Fixya!
Posted on Mar 25, 2009
How to remove error 2 on a cybex trotter treadmill
Hi There,
This error leads to excessive current according to this .pdf.....
http://gymstore.info/manuals/upload/Cybex/cybex_error_codes.pdf
This mentions checking the motor, and certainly could be generated from the lower control board. I recall these controllers as quite large with maybe 4 to 8 large storage capacitors on them, which do fail over the years, and could cause this. Does the tread run at all? Error right away or move the belt then error? You can contact jatinah@rocketmail.com for more help if needed. Good Luck.
Apr 18, 2017 | Exercise & Fitness
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Treadmill will not run error 6
LUBE the deck belt + rollers bearing. see the video God bless you
Nov 24, 2012 | Cybex International CYBEX LCX425T...
Cybex 520T error message 3
Error 3 is a speed signal lost error. Check speed sensor, lower board, drive motor then display.
Feb 08, 2012 | RTO Cybex 520T Remanufactured Treadmill
About 10 second upon start-up, the Cybex 520T Treadmill would abruptly stop and display in the consul is an Err3. We transferred the speed sensor of the unit to another Cybex treadmill and initially the...
Error 3 is an indication that the speed sensor signal has been lost. Check the speed sensor gapping on the machine you were initially having the issue on. If the speed sensor worked on another machine, I would think adjusting it when you reinstall the sensor, should fix your issue. A lot of times, gapping or a build up of lint, dirt or other debris can cause the speed sensor error to occur.
Jul 29, 2011 | RTO Cybex 520T Remanufactured Treadmill
I have a 520T and the motor is getting really hot. The unit has a new motor less than a year old, lower control board that is less than a year old and a new deck and belt. All cybex OEM parts. Any...
If you have not already, I would strongly suggest waxing between the deck and belt. Lack of lubrication will cause a build up of friction causing major heat to go to the lower electronics and drive motor. This can cause an abnormally high amp draw as well.
Dec 03, 2010 | RTO Cybex 520T Remanufactured Treadmill
Hesitation with the belt rotation. Less pronounced at faster speeds.
This is usually caused by a loose belt and can be tightened by the adjustment bolts located on the back of the machine on either side of back roller thru the holes in the shrouds
Oct 19, 2010 | Cybex International Cybex 520T...
I have a cybex 300T and the screen says just "E" Can you help
it is the safety key magnet not in place correctly.. the reed switch cannot pick up the key in place. move the key around on the face of the console slightly.
Feb 21, 2010 | RTO Cybex 520T Remanufactured Treadmill
Mar 25, 2009 | RTO Cybex 520T Remanufactured Treadmill
RTO Cybex 520T Remanufactured Treadmill Logo
263 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
