Question about Marantz CDR510 2-Disc CD Recorder
Getting error message on Marantz cdr510 recorder:
Have turned unit off/on several times to no avail. Have changed out disc's several times and it still reads cdr error
SOURCE: Marantz CDR 615: Msg: ''No CD''
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
Posted on Aug 16, 2009
Obertelli
  • 3006 Answers
SOURCE: On my Marantz CDR-630, how do you erase unwanted
Which recordable disks are you asking about? "Erase" will only work on CD-RW and does nothing on CD-R.
Once you've recorded onto CD-R all you can do is add additional material to it until the disk is finalised to allow it to be played on virtually all CD players. The same goes with CD-RW, but with those you have the option to erase the entire disk and start again from scratch. You can also delete individual tracks from a CD-RW but the space does not become available for additional recordings until the disk is totally erased.
Perhaps you'll find the .pdf manual to be of use:-
http://www.vegalab.ru/forum/attachment.php?attachmentid=65482&d=1256129031
I hope that this has answered your question, all I ask in return is that you return the favour by rating my answer.
Posted on Nov 05, 2009
Testimonial: "Quick response, answer is clear and precise, very helpful, thank you!!"
SOURCE: marantz cdr420 recorded media stored on
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
Posted on Sep 06, 2010
  • 99 Answers
SOURCE: CDR tray
it's more than likely the servo board which is fixed under the mechanism.
this is very common but i'm not sure which component fails on the board but i've always got hold of donor recorders and switched the servo boards and all was fine.
Posted on Sep 12, 2010
SOURCE: I have a Marantz CDR 615 and it won't let me
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
Posted on May 02, 2011
Marantz cdr510 reads cdr error
Please give more details.
Jan 04, 2017 | Marantz Audio Players & Recorders
Marantz CDR510 Display is blank
If that is the case there is a missing B+ line to the display, you will need a circuit diagram to find the fault.
Mar 13, 2012 | Marantz CDR510 2-Disc CD Recorder
Marantz Model DV6600 DVD rewind is indicated on screen but will not play. Simply throws up message for all DVDs and CDs - "Disc Error. Please eject the disc. Playback feature may not be...
Usually means the lens needs cleaning. Occasionally, it's a case of the drive binding. Try running a lens cleaner through it first. You'll want the type that's got optical quality brushes built in to the bottom of the disk.
If that doesn't fix it, it's likely a drive issue, which means it's time for replacing the unit - costs more to fix than replace.
Jul 05, 2011 | Marantz DV6600 DVD Player
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
Lost power while recording a dvd when power came back, i keep getting the "incorrectdisc" error message. I've done the up-channel/play reset/initialization trick several times, but keep getting the...
the "expert's" advice was about as useless as could possibly be- I had already tried all of his suggestions several times before even contacting fixya. what a freaking WASTE of $20.
The only thing left to try is unplug that piece of **** for, oh, say, a month, to let the capacitors discharge completely and hope that the error message goes away. If that doesn't work, the unit is going into the sh*t can.
Oct 05, 2009 | Toshiba DR4 DVD Recorder
I cannot get the CDR510 to record from an external source. At first impression it appears that the analog line-in jacks don't work.
make sure you have the recorder source control turned up and the external device in the input or aux. be sure the external source is sending a signal and not padded or turned down
Dec 04, 2008 | Marantz CDR510 2-Disc CD Recorder
Error message E54040990
Make sure that the discs are right for the unit. As this unit is now absolete you may have trouble finding discs. For one time write, try to find Verbatim Movie Discs 1x-8x. Try Microcenter. Use DVD RW from Maxell 1x-2x. I believe they are still available at walmart.
Aug 01, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Marantz CDR510 2-Disc CD Recorder Logo
76 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
