Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat T8085d 1008
How do you program it. I have no information on it. old house but new to me
hotuna
  • 288 Answers
SOURCE: Honeywell 6300 programable thermostat instalation
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
Posted on Jan 03, 2008
SOURCE: changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Posted on Feb 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 252 Answers
SOURCE: how do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 10, 2009
  • 1015 Answers
SOURCE: want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Posted on Oct 17, 2009
Hi i allredy moved to new house 23/01/17 but rta took money out of my acount for my old house
take it up with RTA and make sure that all the information is updated
Feb 03, 2017 | Computers & Internet
How do I remove the rear axle tube. I need to replace axle oil seal. I have axle out.
would be nice to know what vehicle , make and model you need this information for
if you already have the axle out of the diff housing, just pry the old seal out of the housing and install the new one
no need to remove the axle tube ( diff housing at all)
Mar 30, 2016 | Cars & Trucks
Big pond login
In your new machine's email program, you will have to create a new account, and enter your email name and login information, and all the correct mailserver information same as the old machine.
The exact instructions will be different for each different email program and each email ISP so we can't tell you step by step.
Call your ISP (bigpond) support line or visit their website for instructions on the values to enter into your new email program.
Jun 26, 2014 | Computers & Internet
I have recently moved into a new house and can't get the oven to work. I was hoping to get a manual for the wall oven and see if this information will solve my problem. It is a 1993 model EVBS3193...
So you have moved to a new house. I am assumeing that the Oven worked fine at the old house. I am also assumeing that you have plugged the Oven into your new house and that is when you noticed that it was not working.
If this is the case then the problem may be that the Breaker in the Electrical Sevice Panel of the new house is off. You need to reset the breaker and the Oven should then work.
Jun 12, 2011 | Ovens
Chamberland keypad opener Model 976LM will not program . Craftsman opener has a purple or lavendar training button . Yellow one at old house worked fine.
If I understand what you are saying it is that you are trying to program a keypad from your old house to an opener at your new house. There are several models and you must have the correct one.
Nov 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
Oct 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hello: I recently bought MasterCook Version 11. I presently have version 6.2 on my computer. Can I just install my new version 11 without changing any recipes that I have already added to my present...
If you load a new version of an existing program, it may depend on the new program whether it will overide and revise the existing program or whether it will load as a totally seperate program; thereby having both old and new programs available and most likely 2 different icons on your desktop screen (one for each version).
Some upgrade (Newer) versions will give you the option of choosing to keep the old and have the new one loaded without any interference to the existing version, or to have the new version "take-in" the information of the existing version and then eliminate the need for existing program . In either case, you will not hurt or lose info (that already exits) when loading the new program .
Jul 28, 2010 | ValuSoft Computers & Internet
Installation
Hi, i guess you mean you are trying to copy your old information from your old PC to your new one, you can only transfer information like my documents, pictures, music etc from your old pc, It wont work for Programs. If you try copying the folders for old programs and using them it wont work,
Only thing you can do is backup word documents, letters, pictures and copy them to the new pc. by going into view my files on the autoplay option.
Have a nice christmas
John
Dec 09, 2007 | Computers & Internet
Heating & Cooling Logo
462 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
