Question about HP LaserJet 2420n Printer
HP 2420 solid green ready light and data light and attention red light
All three lights are steady on. The printer does not respond to any command. The window is blank where it usually says ready.
jaylex
  • 417 Answers
SOURCE: HP 4350 printer
EIO is the port for the network card on the back of the machine turn off machine remove card from EIO2 and install into EIO1 turn machine on and see what happens. If this does not work then open the formatter casing and remove the memory chips (OF COURSE WHEN THE MACHINE IS OFF) after removingone turn machine on and see if it boots up.
The 49 error is normally a software issue with the machine and it has locked within the network area or the memory.
Hope this helps you and please rate me
Cheers J
Posted on Dec 31, 2007
jaylex
  • 417 Answers
SOURCE: Hp 2420 not starting up
Hi there you both may have the power board blown the only way to check is plug in a new power cord if this doesn't work then will have to find a repair station.
Hope the cable works though
Please rate me
Cheers J
  • 81 Answers
SOURCE: The printer has a solid green ready light, a solid
Try removing the jetdirect and power cycle the printer.
Posted on Oct 12, 2009
Semi-Driver
  • 434 Answers
SOURCE: The Attention, Ready, and GO LEDs are on solid
LaserJet 1320
This light pattern indicates a fatal error condition. This condition may be resolved by unplugging the unit for 5 minutes. Plug the printer back in and observe the light pattern.
If this condition persists, HP advises contacting their support.
Details of the light patterns for the LaserJet 1320 and their corresponding error conditions can be found at the link below from HP support:
HP LaserJet 1320 Error Light Patterns
I hope this information is helpful.
Posted on Feb 27, 2010
  • 313 Answers
SOURCE: switch on the hp laserjet 1160, The Attention,
you may have a fetal error, press the button to see the secondary error code
Posted on Apr 06, 2010
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
How do i fix a 59.C0 error on my printer?
  1. Turn the printer off, and then turn the printer on.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. NOTE: If this message persists, you will need to contact an HP-authorized support provider.
Sep 15, 2015 | HP Color LaserJet CM2320nf MFP Refurbished
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    Lines on paper produced by lines on drums new
    The link below will provide you with all the necessary information to fix issues related to the HP Laserjet 2420 Printer
    HP Laserjet Troubleshooting
    Also, try the steps below.
    1. Turn the printer off, and turn it on again.
    2. Force a calibration by selecting CALIBRATE NOW from the Print Quality Menu.
    1. Press example (Select) to enter the MENUS.
    2. Press example (Down Arrow) to highlight CONFIGURE DEVICE.
    3. Press example (Select) to select CONFIGURE DEVICE.
    4. Press example (Down Arrow) to highlight PRINT QUALITY.
    5. Press example (Select) to select PRINT QUALITY.
    6. Press example (Down Arrow) to highlight CALIBRATE NOW.
    7. Press example (Select) to select CALIBRATE NOW.
    8. Wait for the printer to calibrate.
    3. Perform a cold reset on the printer.
    3. When the memory starts counting, press and hold the green example (Select) button.
    4. Continue holding the green example (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    6. Press example (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press example (Select). The printer will perform a cold reset and then continue its power-on sequence.
    If this issue persists, contact an HP-authorized service or support provider. ( 1-800-474-6836 )
    If the Toner is newly purchased and it is because of faulty toner, HP will replace it for no charges.
    Regards,
    Shawn
    * Please rate this solution with Thumbs up and Testimony to help us improve providing support
    Jan 05, 2011 | HP LaserJet 2420 Printer
    Error 51.2 y hp color laserjet 4600
    Hi There, Please follow the below steps to fix this issue :
    Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
    3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
    Nov 08, 2010 | HP LaserJet 4600dn Color Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    HP Laserjet 1320 Printer doesn't respond
    Manual Feed or Continuable
    Error
    This state can be reached in
    the following circumstances:
    ● Manual feed
    ● Out of paper for the
    specified tray
    ● General continuable error
    ● Memory configuration error
    ● Personality/Job related
    error
    Solution
    To recover from the error and
    print whatever data is possible,
    press the GO button.
    If the recovery is successful,
    the printer goes to the
    Processing Data state and
    completes the job.
    If the recovery is unsuccessful,
    the printer returns to the
    Continuable Error state.
    Feb 05, 2008 | HP LaserJet 1320 Printer
    HP LaserJet 2420n Printer Logo
    174 people viewed this question
    Seeker5211
    Seeker5211
