Windows can not start this hardware device because its configuration information (in the registry) is incomplete or damaged (code 19).
  • 2 more comments
  • gp2756 Oct 26, 2008
    the Cd/DVD drive will not work. won't read any discs.
    I did as you said and yes there is an exclamation mark there. I tried updating the driver but it comes back with the same error code. Think the drive is gone?
  • gp2756 Oct 28, 2008
    I tried as you suggested and it came back with the same error. I believe the drive is shot. Best Buy told me to bring it by and they will test it and install the new drive if it truely is that. Said it maybe just a software program glitch also. Thank you so much for all your advice, etc.
  • Debs
    Debs May 11, 2010
    what is the hardware device that it cannot start?
  • 903 Answers
Can you check in device manager to see if the there is an exclamation mark next to your device. GO to control panel>system>device manager.
If there is there may be a problem with the driver for this device. Right click the device and do to properties, click on update driver. If this does not help let me know.
Posted on Oct 26, 2008
  • Debs
    Debs Oct 26, 2008
    okay try this before you make the cd/dvd drive as useless.
    1) check that the cables are connected firmly to the back of the drive
    2) Go back to control panel>system>device manager and this time instead of updating the driver, click on uninstall. This will uninstall the drive. Then reboot your computer, this will pick the drive back up as new hardware and install it again. Hopefully if there was a previos registration error in the registry this will bypass it and load new info there and your drive will work. If not then the drive could be faulty. Good luck and I hope it helps.
  • Debs
    Debs Oct 28, 2008
    you are very welcome, If you know the know that model and model numbers of the drives you can always try and update the drives with different drivers than the ones that comes with windows. They may have loaded a generic driver for them and you need that actual driver for that drive for the version of windows you have. If you haven't taken it to Best Buy yet let me know what the models are and I will try and find the drivers for you
Device code 19
go to iobit.com download the free driver booster upgrade for free software and run it to get the correct drivers for your machine
make sure all devices are in place when you run the software from iobit
Aug 17, 2013 | Computers & Internet
I have Optiarc AD-7530B 8x DVD RW DL Notebook Drive Burner, the device status is Windows cannot start this hardware device because its configuration information (in the registry) is damaged or incomplete....
You need to delete the upper and lower filters on the said registry entry.
{4D36E965-E325-11CE-BFC1-08002BE10318}1 You can read the instructions complete with screenshots from the link I added. Cheers!
Fix Windows 10 DVD CD ROM Error Windows cannot start this hardware device...
Feb 20, 2018 | Computers & Internet
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
Code 19 DVD DX not working
  • Open up your Device Manager where you'll see your DVD DX Hardware Device that no longer works correctly. Click it, and then click uninstall. Once uninstalled you can reboot, or click 'scan for new hardware'. Either way Windows will find your Device again and reinstall the driver and probably fix the registry entries.
  • If that does not work, reboot your computer holding down F8 and select 'Load Last Known Good Configuration' before booting into Windows again. It'll restore your settings back when it didn't detect any problems.
Apr 21, 2010 | Computers & Internet
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Error 19
Dear Sir,
Error 19 indicates that the Player and the RealServer were unable to communicate properly. Please check connectivity.
Cheers
Sep 19, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
