Question about Ovens
How does the grill work on the stoves EC600 EM top oven
I cant get the grill to work on the top oven of the stoves EC600 EM DOa MODEL
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 65 Answers
    SOURCE: electric surge turned off the clock,oven but the stove top works
    do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
    Posted on Feb 19, 2008
    • 1462 Answers
    SOURCE: creda reflection double oven and grill
    if fan inside oven starts but no heat, then the probability is that the element is open circuit and needs replacing
    Posted on Jun 29, 2008
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    • 351 Answers
    SOURCE: stoves oven
    check for 110 volts at the igniter if you do have it then change the igniter... whirlpoolpartssurplus.com
    Posted on Jun 25, 2009
    How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
    normal operation is to push the oven knob in and turn
    pushing in sets the igniter off and turning opens the gas flow to ignite
    always light an oven with the oven door open
    stop s an explosion if there is a problem
    down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
    Aug 13, 2016 | Ovens
    Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
    main control board,take it back,its expensive,1 year warranty
    Jul 26, 2015 | Ovens
    Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
    First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
    Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
    If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
    The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
    All the best
    Jul 26, 2011 | Stoves 720EF Electric Double Oven
    Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
    The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
    May 10, 2011 | Stoves 720EF Electric Double Oven
    Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
    First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
    The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
    To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
    So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
    Best of luck
    Nov 23, 2010 | Stoves 720EF Electric Double Oven
    I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
    No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
    Does the top oven work ok?
    When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
    May 05, 2009 | Stoves 720EF Electric Double Oven
    Hi i cant seem to get my grill or oven on can any one help
    thanx for the site guys i got the no for the co and they going to get back to me thanks again
    Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
    Stoves 720EF Top Oven Failed
    there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
    Dec 22, 2008 | Stoves 720EF Electric Double Oven
    Stoves 720ef grill not working
    The grills appear to be independant of each other. Does the oven still work and the oven light come on?
    Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
    Oct 04, 2008 | Stoves 720EF Electric Double Oven
    Ovens Logo
    62 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
