Question about Starbucks Barista Quattro Coffee Maker
Turns off prematurely
While brewing, our coffee maker turns itself off and beeps every few seconds, as if it "thinks" it is finished brewing, when it isn't. We have to stand next to it and keep turning it back on until all of the water has percolated. It's all been said above (although I have the 12-cup Aroma Grande but no category for that model)-- and according to the helpful Starbucks phone support person there is no parts list, and the problem is an internal valve that cannot be replaced. I am more than a little suspicious of an answer like that, but all the unit says is "made in China" so the choices are multiple attempts to use all the water in the tank or buy a new one. Because the only way that the unit can decide it is done is whether there is any water left (hence incoming pressure from the water) I have decided to try multiple de-scaling operations. Really can't hurt, and it's a lot cheaper than replacing a unit that still makes great coffee-- but after several tries!
  • 1 more comment
  • skirabbit Nov 04, 2008
    Have the same problem, and it just started to occur. In frustration, I purchased a Cuisinart 10 cup machine and do not think it does the job of the Starbucks machine. I noticed that my timer light has started to flicker when I start to brew and wonder if the problem could be electrical?
  • ellek321 Dec 13, 2008
    We have the same problem with our Barista Aroma. Frustrating, because it made great coffe, but we've had to go back to our old coffee maker.
  • momrn2 Jan 07, 2009
    Exact same problem except mine only does it toward the end of the cycle, so far.  I am trying to clean it also.  Worth a try.  If yours is not old the store will replace it.  The managers have authority over that. I may even try that at my local Starbucks.  Mine is 4 years old though, a long shot.  Someone has to stand behind it!
Every month run white vinegar thru in place of water. Mine does the same thing if I don't. You may need to run the vinegar 2-3 times at first or every time depending on the minerals in your water.
Posted on Sep 14, 2010
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Turning off the beeper
The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Starbucks Barista Quattro Coffee Maker Logo
306 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
