Question about Sewing Machines
I have a singer futura xl-400 and I am having a problem with the machine
I have looked everywhere and cleaned all the lint out I feel that the bobbin tension is off because it is "nesting" underneath as well
It sounds to me like your bobbin tension is off. Take the embroidery unit off and set the upper tension to "S". Run a line of straight stitches, then a line of zigzag stitches. It is helpful if the bobbin thread and the top thread are different colors for this. If the top thread is almost a straight line, your bobbin tension is too loose. If your bobbin tension is almost a straight line, your bobbin tension is too tight.
To adjust the bobbin tension, take the bobbin case out and locate two screws on the side. The one you want is the straight-slot screw on the left; leave the Phillips on the right alone. The rule is "lefty-loosy", "righty-tighty" turn in the correct direction only 1/4 turn and sew another line; you should see SOME improvement, but it may take repeated attempts to get it in balance. When it is, put the unit back on, and don't forget to change the upper tension to "E".
Posted on Feb 06, 2013
  • Kim D Aug 06, 2013
    I am having the exact same problem, but supposedly the bobbin tension is unadjustable. I am going to try the above advice. Thank you!
  • Robbie
    Robbie Sep 07, 2015
    I tried your advice and it worked!!!! My only issue now is that the white bobbin underneath is not symmetrical. I see other projects underneath and the white bobbin is a clear "row" if you will, on the bottom. Mine is a little erratic. Is there anyway to fix that?
    New Friend:
I was having the same problem. When I took out the bobbin case, I saw the culprit - the tiniest piece of a broken needle. Removed that, problem solved. So random!
Posted on Mar 23, 2017
SOURCE: Bobbin thread getting all nested underneath fabric
My experience is the bobbin not in correctly. Its worth a try. nancy
Posted on Apr 03, 2009
  • 51 Answers
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Posted on Sep 06, 2009
SOURCE: Singer Futura 900
Complete instructions for filling the bobbin and threading the Singer Futura 900 can be found here:
Posted on May 07, 2008
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
  • 48 Answers
SOURCE: Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Posted on Feb 19, 2010
I'm looking for a Manuel and a start up cd for a xl 400 singer embroidering machine..
Singer has the manual for the Futura XL400 on the product site: . The direct link to the instruction manual is . There is also a quick start guide. Additional documentation and driver upgrade software is here: . Unfortunately, Singer doesn't provide replacement CDs if you lost the original one. According to the directions for the driver upgrade, you need the CD to install the upgrade.
The software packages are available for sale at Amazon and other vendors. Some CDs may be available on E-bay.
I hope the manual helps.
Jul 05, 2017 | Singer Sewing Machines
How do I resolve E01 code?
Does your manual have an Error Code section? It should tell you the problem specific to E01.
Aug 17, 2015 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Why wont my singer futura xl-400 bobbin case stay in place and keeps getting jammed
Hi, I just want to make sure. Do you put the bobbin under the little hook and then pull it up the case?
Jun 06, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
Sewing Machines Logo
2,657 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
