Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Remove agitator on a whirlpool ultimate care II washer
I have something under the agitator, how do I get the agitator out to remove object, I popped the rinse dispenser out but didn't want to start prying under it without knowing how to do it
Thanks
  • 958 Answers
Have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Posted on Oct 25, 2008
GE washer model # WHDRR418E4WW : Having trouble removing the plastic cap under the fabric softener dispenser, so I can access the agitator bolt.. There appears to be no simple way to remove it. There are...
that's right just put your fingers under agitator and pull up,under the agitator is a coupler that has a screw in it,whirlpool has the nut in there,if you have a problem with the agitator not moving the clothes around that coupler wears out and has to be replaced.
Oct 07, 2017 | Washing Machines
How to remove the agitator on a GE ProfileWPSR3120W0WW? The utube video (describing a bolt at the bottom) does not describe accurately what we have. Softener dispenser removal only yields a clear plastic...
Your washer is close to the one in the video but as you know not exact..that agitator coupler shown in the video bolts down under the agaitator. To remove your agaitator which locks into teh agaitator as shown just pulls off....so to remove your just grab the bottom of it and pull straight up and off of the agottaor coupler.
GENE
Sep 07, 2011 | GE Profile WPSR3120WWW
Shirt caught under agitator how do I get agitator out to unwind shirt
you need to pry the softener dispenser cup off the top of the agitator,then you need a 7/16"socket with an extension to remove the nut located down inside there,then lift the agitator straight upward
Mar 23, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
How to take apart a fabric softener dispenser to clean
it just pull up. using 2 hands move side to side while pulling up. then take to sink and using warm water and a old toothbrush clean. rinse by shaking water out. you may have to repeat several times the process.
good luck to you.
Feb 19, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do we get the adgitator out? Lost a piece of jewelry... want to see if it's lodged underneath Email or call 419.236.6996
If you have the softener dispenser cup, remove it by pulling up on the blue ring, and then pop the cup off. This exposes the flat agitator cap. Gently pry it up to get it started, and it, too, will snap off. If you have a dust cap inside the agitator, remove it. This will expose the 7/16" hex head screw that attaches the agitator to the shaft. Remove the screw and the agitator will lift off the shaft.
Dec 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i remove the agitater to clean under it
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle or something of this nature against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Apr 23, 2010 | Frigidaire Washing Machines
We have a Kenmore washer/dryer stacked unit, model 417.94802301, that we need to replace the agitator on. Can someone tell me how to remove the agitator? Underneath the dispenser, it just a solid piece...
GO TO SEARSPARTSDIRECT.COM FOR A BREAKDOWN. yOU SHOULD BE ABLE TO GRAB THE TAB ON THE "WHITE THING" AND PULL IT STRAIGHT UP. tHE SCREW IS HIDDEN UNDER IT.
Nov 20, 2009 | Kenmore Washing Machines
Kenmore elite washer not agitating properly
pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool top load washer
Bill,
On most top load whirpool washers (not including the calypso or the cabrillo) there are 2 main styles for getting the agitator off.
The first and easiet are for the older styles. This will be easy to identify as there is a green ring around the fabric softner dispenser holding it on. Raise the ring up and the dispenser will come off. Underneath you will see a plastic cap. Pry this off with a small flat hear screw driver. Underneath there, there will be a 7/16" bolt. Take it off with a rachet and lift the agitator from the bottom and out of the way.
The second and slightly more complicated method is for the new style. This can be identified by the 4 evenly spaced slots just underneath the fabric softner dispenser. First gently rock the top of the fabric softner side to side. the white top should come off as well as a clear plastic cup underneath. You will be left with 4 white plastic shafts sticking up just above thse slots mentioned earlier. Taking care not to break these shafts, rotate the remaining top piece of the agitator counter clock wise. Once it rotates, pull/ pry it off. Underneath there will be a clear plastic cap with 2 tabs on it. Pull the cap off by these tabs. Remove the remaining 7/16 bolt underneath and lift the agitator off by the bottom.
There are many variations of agitators, but one of these 2 methods (or even a mixture) should get you taken care of. One other thing to mention. Once you take either of the perviously mentioned styles off, you may find a white square hole under neath the dispensers. With this style, you use a 1/2" rachet to unscrew it counter clockwise and the 7/16 bolt is underneath.
If this doesn't seem to match what you have, get me the model number (just underneath the lid to the center rear) and I can get you some step by step directions just for your model.
Aug 01, 2008 | Washing Machines
Noise in washer need to know how to remove agitator
For most Kenmore, Whirlpool, Estes, Maytag, and some GE washers the top portion of the agitator can be pried off (either a cap or fabric sofrtner dispenser depaneing on make and model) and there is a bolt underneath. Once removed, the agitator can be lifted straight out. Some GE's you have to actually "pop" the agitator by placing a strap underneath and lifting it out that way. If your are still having trouble, reply back with your model and serial number and we can go from there.
Jun 18, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
763 people viewed this question
Dan Webster
Dan Webster
Sal De
