Question about Thermador C301U Electric Single Oven
Clock display too dim
The clock / LCD display in my oven is too dim and sometimes you can hardly read the numbers. Any idea on how to fix this? Thanks
  • minepapa Apr 24, 2008
    Myself and four others in the neighborhood with the SC301TS Thermodor oven made from 2001 to 2004 have the same problem. What is the experience with longevity of the replacement kit? If it is the same quality as the original and has not been upgraded it doesn't seem worth it. Any experience with the replacement kits? Is there any source for just the clock component board?
  • 175 Answers
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Posted on Oct 06, 2006
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display blank
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Ovens
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Dimming temperature and clock light on display window
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Dec 30, 2006 | Thermador SC272T Electric Double Oven
Thermador C301U Electric Single Oven Logo
271 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
