Question about Sony SLV-740HF VHS VCR
Sony slv-t2000 hi 8 vhs trilogic
  • 4 Answers
SOURCE: Sony VCR date only goes up 2006
I have 2 SLV-696HF units that won't work after 2007. I have had people tell me that I'll have to "find" a previous calendar that will work, since there are only 14 different calendars in our Gregorian system, 7 for non-leap years & 7 for leap years. The problem we have with this, is that the internal VCR calendar won't roll BACK far enough. I wonder if SONY has a way of flashing these units to fix this problem?
Posted on Mar 03, 2007
SOURCE: Sony SLV-SE820 VHS VCR
o Front display,wrong functions on front buttons.
CAUSE
Corrupted data is stored in the NVM memory (IC605) or part of the data is erased.
The model option data flags are erased or set incorrectly.
SOLUTION
1. CAPACITOR AND RESISTOR REPLACEMENT NOTE
For continuous reliability, regardless of the symptom, ALWAYS check and replace if necessary C701 in the correct mounting position and ALWAYS modify R668/R669 from 10k to 4.7k.
1.1. Open the set and replace C701 "470µF 10V" (1-126-925-11)
1.2. Make sure to mount C701 in the correct way, the positive (+) side points to the edge of the MCB. NOTE THAT THE WHITE PRINTING FOR C701 ON THE MCB IS INCORRECT (REVERSE)!
1.3. Replace R668 and R669 "10k" (1-216-675-11) with "4.7k" (1-216-667-11).
2. OPTION DATA SETTINGS
2.1. Connect the unit to the AV input of a television with a SCART connection cable in order to enable the on-screen display.
2.2. Enter the unit into test mode: press the record button on the front panel, then press the menu button on the remote commander for 5 seconds until the option setting display appears on the connected television. The option display has 8 columns and 9 rows with decimal numbers.
2.3. Enter the correct option settings according to the model and model destination. Refer to the option setting table in this document or page 5-6E of the Service Manual.
2.4. The option number is selected with the FF, REW, STOP and PAUSE buttons on the remote commander.
2.5. Pressing the OK (PLAY) button on the remote commander activates the selected option number. An activated option number appears in reverse colour.
2.6. After all required option numbers are activated press the MENU button on the remote commander to save the changes. A message "Please wait" appears for a few seconds after which the setting is completed.
2.7. Turn the power OFF and back ON.
3. HEAD SWITCHING PULSE ADJUSTMENT
3.1. Remove the front panel.
3.2. Insert a VHS alignment tape (like KRV-4821PS).
3.3. Press the TEST button located behind the front panel at the left-hand side of the tape/display area.
3.4. Press the SP/LP button on the remote commander. The adjustments are operated automatically.
4. FUNCTIONAL CHECK
4.1. Re-assemble the unit and perform functional checks.
4.2. Check for correct language setting.
4.3. Confirm basic functions like Playback, FF, REW, etc.
4.4. Check for a noise-free picture quality in playback mode.
4.5. Switch the unit on and off for a couple of times.
4.6. Perform a timer record to confirm the function and picture quality.
4.7. Check the SmartLink function (if available with the connected television) by transferring the TV preset settings to the VHS recorder.
MODELS OPTION DATA SETTINGS
SLV-SE720D/SX720D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720E/SX720E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 27, 33, 34, 35, 40, 41, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720I
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 25, 26, 33, 34, 35, 40, 43, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 21, 26, 33, 34, 35, 36, 40, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SX727D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE727E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720N/SX720N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 36, 42, 45, 47, 51, 54, 60, 61, 63, 66, 69, 72
SLV-SE820D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 27, 29, 32, 33, 34, 35, 40, 41, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 21, 23, 26, 29, 32, 33, 34, 35, 36, 40, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 23, 29, 32, 36, 42, 45, 47, 48, 49, 50, 54, 60, 61, 63, 64, 66, 69, 72
Posted on May 12, 2008
  • 4234 Answers
SOURCE: Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Posted on Aug 31, 2009
mybradley7
  • 242 Answers
SOURCE: Trying to find fuse number for sony vhs recorder
Check google and search for sony slv n50 fuse number.
Posted on Jul 15, 2010
  • 5422 Answers
SOURCE: Where can I get a remote control for the Sony VHS
You can get a duplicate of the original remote (new or used) here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=SLV-685HF&uuid=12875134515770 for the 685HF. I can not find the SLV 685HS is not a valid model that I can find at either Sony Parts or Remotes.com.
However, a refurbished remote for the SLV685HS is listed at: http://www.replacementremotes.com/SONY/Buy-RMT-V231A-RMTV231A-147555321-Video-Remote-Control.html . (E-bay also lists a few remotes for th SLV685HS; these listings may or may not still be valid.)
I hope this helps.
Posted on Oct 19, 2010
Testimonial: "Thank you for your help by clearly and completely answering my question."
Sony slv-998hf has loose part
Look for a junker on eBay or similar. This reminds me, I have several machines I can sell for parts!
Nov 13, 2013 | Sony SLV-998HF VHS VCR
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
Mar 30, 2013 | Sony SLV-N750 VHS/S-VHS playback VCR
Trying to find fuse number for sony vhs recorder slv-n50
Jun 24, 2010 | Sony SLV-N50 VHS VCR
How can an NTSC 8mm tape be played on the Sony SLV-T2000?
There is no way to play 8mm tapes on your vhs vcr. You would need a 8mm to vhs adapter which is not available.
Nov 10, 2009 | Televison & Video
Hi! I'm looking for a user manual for my newly acquired Sony SLV-2000 VCR. I've Googled and gotten nowhere. Lots of dead-ends. HELP!
Problem solved. I went online and found a pdf file for the Sony SLV-R1000 manual. This manual works just as well for the Sony SLV-2000. I'm a happy camper...
Jan 08, 2009 | Sony SVO-2000 S-VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Sony SLV-740HF VHS VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
