Question about Sony KP-51HW40 51" Rear Projection Television
Arched picture picture is arched and its out of focus, this just happened, I have the same problem, it even happened on saturday morning as well, it must be the weekend moon...
    Scholar:
  • 136 Answers
Loosed solderings on the main board or the problem with convergence ic
Posted on Oct 25, 2008
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Are there any pictures showing where to attach the freon canister to on my 2003 Ford Focus air conditioner?
The low pressure port is behind the passenger fender liner. Remove the right front tire so you can remove the liner.
Detach the wheel arch trim panel on the passenger's side (driver's side shown).
  • Remove six bolts.
  • Remove the trim panel.
Jun 25, 2009 | 2000 Ford Focus
There is a arch at the bottom going to the left
Covergence needs to be fixed replace Both of your ICs they are big black ICs with STK on them for example STK392-110 if this the # on yours use 180s better ics.For parts Call 1-800-223-3205 www.electronix.com.
Dec 26, 2008 | Toshiba 57H82 57" Rear Projection...
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
The SAF that shows up on the LCD
Dear Morgansha,
SAF is Micro setting of lens for close-up focus. This function can be ON-OFF by cursor button. it has symbol like little flower.
May 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
Problem with memory card
Take out the memory card from your camera and insert it in another camera could use this type of card. It will let you know if your problem is with the camera or the memory card. Good luck!
Aug 07, 2007 | Canon PowerShot A530 Digital Camera
Out of Focus
hi speedster, Obviously it is happened due to sand getting in the camera and i also hope that water not getting in the camera. i suppose lens drive that is very delicate get jamming due to sand or it may be short circuit due to water. i think that's why your picture is out. so go to casio shop. good luck....
Aug 01, 2006 | Casio Exilim EX-S600 Digital Camera
Sony KP-51HW40 51" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
