Question about Onkyo Audio Players & Recorders
I have a onkyo ht-r320 everytime i turn it on it cuts off the fueses are good what should i look for next?
  • 3 Answers
Did u recently move or swap plugs? might have a bad ground check the gfi and internal ground.
Posted on Feb 15, 2012
  • nowens501
    nowens501 Feb 15, 2012
    its my brothers so its been moved to my house but the power cord is the same. how do i check the internal ground
5 Suggested Answers
  • 1121 Answers
SOURCE: onkyo receiver memory power backup not working
there is a special memory chip who keps thre config. The older models has a battery who power memory offline, and that battery has 5 years life, and needs to be replaced. or new models has a eeprom who keeps data above 10years, normaly some chips has small defects who reveal after 4 or 8 years, normaly also needs to be replaced.
Posted on Dec 22, 2009
  • 319 Answers
SOURCE: zone 2 cut off on onkyo
Your program source may not support a 7.1 format. Try switching to 5.1
Posted on May 07, 2008
SOURCE: My Onkyo HT-R320 receiver keeps cutting out while
Check the speakers maybe one are about to burn
Posted on Aug 31, 2009
dunnbiker
  • 8546 Answers
SOURCE: when ever i turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 24, 2011
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I am using Onkyo HT-R320 for past 6 years. It was working fine and i connected via digital cable. suddenly i couldnt hear the audio, but the video is working fine. i verified all the setting (audio select...
I don't have a fix but I think the general explanation that could explain both issues would be that the memory for your settings isn't being retained. Check to see if the digital audio source you're having trouble hearing still has its input assigned to it. I'm thinking all your settings go back to 'factory' when you turn it off.
See this entry:
http://www.fixya.com/support/t3692493-onkyo_receiver_memory_power_backup_not
Page 36 of the manual discusses the Memory Preservation theory.
http://www.retrevo.com/support/Onkyo-HT-R320-Receivers-manual/id/367dj085/t/2/
You COULD also try a forced microcomputer reset once just to see if that resolves the issue (same page).
Jul 12, 2011 | Onkyo HTR500 Receiver
Onkyo receiver memory power backup not working
How change battery and the battery model
Dec 22, 2009 | Onkyo TX-SR700 Receiver
Power cord cut can it be fixed
Yes, strip the wire from both cut ends. then find the same color wire, and solder them back together. then isolate them from eachother and your good to go.
Dec 24, 2008 | Onkyo HT-S790 System
Keeping the settings permanent
Hello, are you making the changes in the speaker settings section in programming? Thank you, CB
May 24, 2017 | Onkyo HT-S670 System
ONKYO HT R320
The fuse is internal. You'd need to take off the cover and look inside it. If you did that and took it to an electronics repair shop, they should be able to tell you where the fuse is by looking and help you find a replacement.
May 16, 2008 | Onkyo SKS-HT510 System
Zone 2 cut off on onkyo
May 06, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT R550 sound going in and out
Sh$T I had the same problem with an older model... went out and bought a new Onkyo... HT-R550 I have had it for 2 years as of January 2010
Dec 06, 2007 | Audio Players & Recorders
146 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
