Question about Whirlpool Washing Machines
My Whirlpool Front Loading Washer will not spin at the highest speed to spin out the water.
  • 3 Answers
Its either ur motor or belt worn look for abnormal wear on belt
Posted on Feb 15, 2012
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
aborcass
  • 2651 Answers
SOURCE: My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Posted on Mar 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: My GE front loading washer model #wssh300goww
Your drain is most likely clogged.
The timer runs out, and the water has not completely drained.
Just before the pump, there is a screen cup that needs to be disassembled and cleared of debris. Many times small articles of clothing or coins can block up the passage.
CLICK HERE for all the blowout diagrams of your washer.
THIS ONE - of the tub and motor - specifically - shows the filter cup (part #340) circled.
This is a common design flaw in front load washers - and easily remodied.
If you require further clarification about your question... please use the "Continue With This Expert" option so we are connected in the future.
Thank You for using FixYa!!
Posted on Apr 29, 2009
  • 126 Answers
SOURCE: Whirlpool LSR5233EQ0 top loading washer wont spin
I'VE HEARD THIS SONG BEFORE FILL, NO AGITATE, DRAIN, AND NO SPIN. YOU HAVE A STRIPPED DRY COUPLING, WHICH IS A PLASTIC RUBBER COMBINATION THAT CONNECTS THE MOTOR TO THE TRANSMISSION. REMOVE SCREWS AND FLIP TOP CONSOLE UP. FLAT HEAD SCREW DRIVER REMOVE CLIPS AT CORNERS, DISCONNECT 2 WIRE PLUG. PULL WHOLE OUTER CABINET TOWARDS YOU AND PULL AWAY FROM MACHINE. LOOKING AT THE BOTTOM CENTER, REMOVE SCREWS HOLDING MOTOR CLIPS, DISCONNECT ALL PLUGS (HARNESSES) AND REMOVE MOTOR. COUPLING WILL BE VISIBLE AND PEGS/RUBBER WILL BE WORN, REPLACE AND REASSEMBLE
Posted on Jun 24, 2009
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
What does "F6: mean on my front loading washer?
F/6 is a Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool front loading washer is flashing f 6 - What do I do now????
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
May 20, 2010 | Washing Machines
Have a whirlpool model.# LSR 8444LQ0 Balance problem anyone know what maybe the cause and a fix it for it?
Check your machine standing level. Adjust it with it's adjustable screw legs.
Check the set of springs or hydraulic shock obsorbers ( depending on mododels) that supends the water drum assembley set.
Check drive belt tension. during high speed spin might slip intermittently.
Finally your loading material!
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Mar 19, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
