Question about Gateway FPD1975W 19" LCD Monitor
Monitor says no signal
I was moving stuff on my desk last night and accidentally pulled the cord out of the monitor and when i plugged it back in it said no signal and i have plugged another monitor into the computer and it says the same thing and the monitor works on my other computer, i think it is my computer but how? i didnt even touch the tower, just the monitor plug came out and i put it right back in
  • lgm2465 Oct 27, 2008
    have already checked that and compleely hooked to another computer with a different cable and it worked fine.then i hooked another monitor up to the computer and got the same thing with it
  • rjulun Nov 29, 2008
    gateway fpd1975w screen goes black. If you look at it from an angle, you can see what is actually on the screen really faint.
  • 849 Answers
The cable has two ends, see the other end
Posted on Oct 27, 2008
Moved monitor to get to my modem. Buttons on bottom accidentally hit/sat on my fax machine. Now all I get is HDMI No Signal message then monitor goes immediately into sleep mode.
check hdmi cable in back of monitor and also in back of computer.
also try to restart monitor by taking out power cord and plug back in.
Mar 11, 2016 | ASUS Computers & Internet
Monitor says "No Signal" when trying to wake it up
I had that problem awhile ago, but the issue was a loose connection.
If you test your PC with another good working monitor/cable and still receive a no signal message, then the problem is with your PC.
The solution could be as simple as dust inside the unit interfering with the signal, and needs to be blown out, or try removing the power cord and hold-in the 'on button' for about 30 seconds to a minute; then reconnect the power cord and turn it back on.
Other solutions: open up your PC and take out and put back in the video card; remove the ram memory strips, rub the end gold colored strips on a clean cloth and put them back; or maybe you have a bad video card.
Mar 23, 2015 | AOC Computers & Internet
My monitor flashes on and off.If I press any button on the side of the monitor it comes back on. It has been doing this for quite some time. I've checked the VGA cord but it seems to be okay. It seems...
Well, it's impossible for me to say 100% for sure, but I think i know what's going on. It sounds like either the cable for the monitor, or the port on the computer are either dirty, or broken.
What usually causes this is the electrical signal from the computer is getting interrupted. It's the same thing that happens when you try to hold a light switch in between the on and off stages. Sometimes the signal makes it though, other times it doesn't.
Fixing this can be somewhat tricky. I would attempt these steps:
  • Unplug the cable and plug it back in.
  • Try blowing off both the port on the computer, and the end of the cord that plugs into it.
  • If you have another monitor available, plug that in and see if it still happens.
  • If you have another computer available, plug the monitor into it and see if it works.
If none of these help, then something more complicated is wrong with it.
Hope this helps :)
Feb 24, 2011 | E-Machines eMachines Desktop PC
Lost the sound and YES my speakers are on and I have moved the bar all the way up to 100% ,,,not even as much as a peep,, the sound was on last night but its off now and I have tried to fix ix it.....
have you checked:
1. The audio plug that connects to the rear of your computer (not accidentally pulled out partially)
2. The other end of that cable which plugs into your monitor (usually a red and white plug arrangement, but could also be a small stereo plug)
3. That the speaker icon on your taskbar has not been accidentally "muted" (indicated by a red circle with a slash line)
4. Checked your audio properties (right click the speaker icon) for anything out of the ordinary?
If all of the checks above are good, and assuming your audio cable is OK, I would try and reload the audio driver. You could also try the Windows Troubleshooter. Search your Help for assistance on the troubleshooter program.
Ask me for more help.
Cheers, Steve
PS Feel free to vote for my answer or give a testimonial for me if I have helped you.
Oct 31, 2010 | Acer 22" X223w LCD Monitor
I have a viewsonic computor monitor...I was hook up to 2 monitors..When I unplug one I cannot get a signal from the one left...check all plugs and wires
Things to try.
Move the signal (VGA) cord going to the monitor from the computer, from the one output, onto the other output.
If you removed the primary monitor without changing your display settings, then your second monitor will have nothing to extend from.
Another possibility is that the second display is disabled since there is no monitor detected.
Also, Be shure the power cord plugged into the back of the monitor, is pushed in all the way. These tend to slip out a little when getting moved around.
Hope this helps.
Dec 11, 2009 | Computers & Internet
Wave like disturbance in monitor after moving
change your refresh rate on the monitor, plug it into a ups to regulate the power. may have emi interference coming from other sources
Aug 06, 2009 | iiyama Computers & Internet
Last night I moved my living room around and moved in a new computer desk. When I hooked everything up the monitor is now not receiving any signal. I have checked all the cords and have restarted. Other...
Open the side of your computer. The card that your monitor plugs into may have come loose. Carefully pull it from the slot (you may need to unscrew it first or remove a bracket that keeps it stable; plus there may be a lever at the back of the card you may need to pull on) and then plug it back in again. It is not uncommon for this card (called the video or graphics card) to come loose when being moved around.
Jun 07, 2009 | Generic Memory Compaq Presario SR1215CL by...
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
Gateway FPD1975W 19" LCD Monitor Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
