Question about RCA R52WH73 Projection Television
The menu screen pops up and won't go away.
The menu screen pops in and out. sometimes it won't go away. the volume will sometimes go down and won't stay up. thought it was a remote control issue, so i took the batteries out of remote, thinking it would stop... it didn't make a difference. it's been going on for like a month now.
  • j_cress Nov 12, 2008
    I am having the same problem with my RCA r52wh74......did this work to fix it?
    Genius:
  • 1,030 Answers
I see this alot at the shop common problem... the front conrtrol buttons have become damaged. you need to replace it. You can remove the front panel and leave it out until you can get the front keyboard cuicit board. Just use your remote to control the tv. to remove the board just remove the front middle panel via the t20 torx screws. then unplug the connector. You can get a new cuicit board via union electonics... you need the entire model number...r52wh73 yx1 or yx2 something like that it is in small letters on the same label as the large model number, Let me know if you need any more help on this repair.
Posted on Oct 31, 2008
Blackberry 8520 won't reboot goes half way then stops took battery out left all night still won't go any further what can I do ? Please
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Feb 08, 2013 | Cell Phones
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
Mar 23, 2011 | LG W2284F 22" 2ms LCD Monitor - Black LCD...
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume bar won't go away
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Mitsubishi 55 in. WS-55315
Go into the menu and see if your closed captions are on and set to "TEXT". Setting the closed captions to "OFF" should solve your problem.
Jul 26, 2007 | Mitsubishi WS-55315 55" Rear Projection...
RCA R52WH73 Projection Television Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
