Question about Emmaljunga Viking Plus Stroller
I have an Emmaljanga S280-22 Vittsjo strooler with a broken plastic chassis lock were in the uk can i find this part
Drivers door 2003 lock button not working
if button not working -locks with key fob or when put in gear the lock switch can be bad or plastic button check for power to the switch if power switch malfunction --if not working with fob or when put in gear locking mechanism problem -short-plastic clip broken/ disconnected --wiring connector disconnected/ corrosion== to check lock system will have to remove door panel
May 23, 2014 | 2003 Chevrolet Tahoe
The frame clip lock for quinny buzz is broken...
Hi
If you're in the UK a replacement transport clip for your Quinny Buzz can be ordered from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 7.50GBP and if ordered direct there is 3.99GBP additional p+p.
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the screen for your enquiry to go through to the customer care team for your country who can help you source a transport lock.
Feb 02, 2012 | Quinny Buzz Baby Gear
Dont know how to close bebecar multipla sport
To fold a Multipla chassis, you must first lock the swivel wheels in the non-steering mode and ensure that the adjustable handle is in one of the middle positions. To fold it, firstly press the red button and simultaneously, turn the handle collar, in the middle of the handle bar, in the direction of the "FOLD" arrow, and the chair will begin to close. Next, operate the secondary safety device by pulling upwards the plastic tab situated on the right hand side. Tilt the chair forward and continue the folding action until the chassis is fully closed. If you want to store the pushchair, fold the adjustable handle down. Find out more by asking service@bebecar.co.uk for a user-guide.
Sep 26, 2010 | Toys
I can not fold my bebecar raider at stroller
Firstly, remember to lock the swivel wheels in the non steering
mode before folding chair.
To fold, firstly press the red button and simultaneously, turn the handle collar in the direction of the
"FOLD" and the chair will begin to close.
Operate the secondary safety device by pulling the plastic tab.
Tilt the chair forward and continue the folding action until the chassis is fully closed. Why not ask for a user manual at service@bebecar.co.uk
Aug 25, 2010 | Bebecar Raider AT Stroller
Broken fold down bungee lock. I need to replace possibly the entire handle. How can I order?
Hi I am not sure if it is replaceable. try dorel uk, other than that get some black velcro or a nice colour and use that as a locking device around the frame.
Jul 22, 2010 | Quinny Buzz Three Wheel Stroller
I have a bebecar sport with a broken chassis clip 4 wheel type
You'll need to narrow your description of this broken clip down a little more. "Sport" is actually a fabric design, whereas you'd need to sepcify a chassis model, such as "R-Versus", "Stylo", "Vector" or "Multipla", etc. etc. Also, how old is it? Your best bet would be to get in touch with service@bebecar.co.uk. They may ask you to provide a photograph of the broken clip, if they're unable to work out what it is from the description. Good luck!
Jun 29, 2010 | Toys
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
We bought a 3 weels quinny stroler 2 years ago , it opens very easy when we take it aut of the trunk , my wife olmost broke her fingers , this hapen the second time . theres no safety on it . i went to see...
The Buzz you bought was fitted with a safety strap. If you stand at your buggy as though pushing it, on the left side of the handle just below where the top rails turns through 90 degrees towards the buggy, there should be a plastic O of a piece of tight bungee elastic that pulls out and snaps over a pin on the chassis when in the folded position. If this is not there then it has been broken off. I suggest you speak with Dorel UK 01842 763 281 (Mon ? Fri, 8:30 am to 4:30 pm). They are the sole supplier of parts/repair for Quinny in the UK
Mar 05, 2010 | Quinny Buzz Three Wheel Stroller
Audi A6 Xenon headlamp bulb change - UK Offside
Headlights, Removing and Installing
Removing
  • Remove front bumper.
  • Remove both Torx bolts (T30) -1-.
  • Remove interior Torx bolt (T30) using 1/4"-Torx-bit insert and extension.
NOTE: If necessary, use magnet to remove bolt.
  • Disconnect multi-function harness connectors for headlights.
  • Turn headlights -2- toward center of vehicle and remove from chassis toward front.
Installing
Installation is reverse of removal, noting the following:
  • Adjust dimension -a- via plastic bolt at new headlight.
NOTE: Determine dimension -a- at plastic bolt of old headlight, when being replaced
  • Engage headlight in area of center of vehicle in guide -2- via pin -1-.
  • Always align headlight according to contours of chassis (gap dimensions) and secure.
  • Adjust headlight after installing.
Tightening torque
Component Nm
Headlights to lock carrier 6
Repair Kit For Headlight Housing, Installing
NOTE:
  • Headlight mounting tabs that have broken off can be replaced by installing the repair kit. Complete replacement of the headlight is therefore not necessary.
  • Different repair sets are available for the left and the right headlight.
  • Remove headlight with broken mounting tab.
    • Remove remains of the broken mounting tab -1- at location marked with the arrow.
    • Place mounting tab -2- of repair set onto the edge (arrow) of the headlight housing and secure the tab with two screws -3- from rear.
Feb 09, 2009 | 2004 Audi A6
Baby Gear Logo
98 people viewed this question
Top Emmaljunga Baby Gear Experts
Dorel UK
Dorel UK
Randy Hobbs
Randy Hobbs
Level 1 Expert
Are you an Emmaljunga Baby Gear Expert? Answer questions, earn points and help others
