Question about Intermec EasyCoder 3400 Thermal Label Printer
How to calibrate intermec 3400e
Power light blinking
3 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: Intermec 3400E: Label prints
Hi
There are three common causes for this problem:
o An incompatible printer driver.
o The paper source is set incorrectly on a dot matrix printer.
o A custom label Down Page or Page Length setting is incorrect.
The resolution for each problem is listed below. Incompatible Printer Driver.
Contact the printer manufacturer to obtain the latest version of the driver for your printer. As an alternative, see your printer documentation for other printer models that your printer can emulate. Then, install the printer driver for one of those models.
For information about installing printer driver software in Microsoft Windows, see your Windows printed documentation or online help.
Paper Source Set Incorrectly on a Printer
1. On the File menu in Works, click Page Setup.
2. In the Page Setup dialog box, click the Source, Size, And Orientation tab.
3. Select the correct option in Paper Source. For example, if the Paper Source is set to Manual Feed and you are using tractor fed labels, change the Paper Source setting to Tractor Feed.
4. Click OK.
Custom Label Settings are Incorrect
5. Open the Word Processor label document in Works.
6. On the Tools menu, click Envelopes And Labels.
7. Click Custom Label.
8. Make sure the Down Page text box correctly reflects the number of rows of labels on the page you are using. Click OK.
9. Make sure the Page Length text box correctly reflects the length of the page you are using.
10. Click OK. Click Change Label.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 26, 2011
  • 395 Answers
sensor and roller are first one you need to check to make sure they are still good to pick up the labels and feed them through
Label size and type are another one to make sure they work you this type of printer. If label is to thin, it will cause issue
Label stock may not be loading properly. Please make sure pay attention on this too
Update printer firmware and driver are the last steps. Make sure you have latest firmware and driver for this printer.
We have this issue once in the while. Most of the time label type and size are the causes
Let me know which OS you are using, i will try to find the latest driver for you.
Thanks
Paper fault with intermec pm41i
Sound like you need a new label or paper sensor. We have inhouse technical teams who can repair this problem for you. jack@codeo.co.uk 01179064587
Nov 08, 2011 | Intermec EasyCoder PM4i Printer
Yellow light is lit (Empty/Pause) but there is paper in printer.
I've found that if the ribbon core is slipping on the TTR supply hub, it causes the ribbon sensor to think the ribbon is not moving. This, in turn, causes the yellow light to come on. Take off the ribbon and replace hub core locking bracket (p/n: 065375-003). I have also found you can bend the bracket enough to work if you don't have any on hand. I hope this helps with your problem.
May 03, 2011 | Intermec 3400E Thermal Label Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Network Card
INTERMEC TECHNOLOGIES 72884
Internal EasyLAN Ethernet Card (for the 4420e, 4440e and 3400e)
Oct 22, 2007 | Computers & Internet
Intermec EasyCoder 3400 Thermal Label Printer Logo
337 people viewed this question
Top Intermec Office Equipment & Supplies Experts
pkwc
donjackson
Level 1 Expert
Paul Bade
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
