Question about Elna 1010
Elna 9000 presser foot
When I release the presser foot (down) it goes VERY slowly and does not seem to go all the way down, therefore the material is not tight against the plate. Is this a cleaning issue?
  • Anonymous Mar 29, 2014
    The lever for the presser foot goes up and down but the foot only goes up a small distance, not enough to get material under. How to fix at home?
  • 323 Answers
This is a cleaning issue. There is gummy residue holding your presser foot bar which needs to be cleaned out. Unfortunately, you need to split the case on your machine to access it for cleaning and this is best done by a qualified technician. Let's face it, it's probably been a long time since the machine was serviced anyway and they do work better with regular servicing.
sewman7
Posted on Oct 25, 2008
Elna 5200Q The material is bunching up in front of the feed dogs
Are the feed dogs actually raising, moving, and dropping (raise the presser foot and hand-rotate the handwheel and watch how the feed dogs are moving)? If not, check to see if the stitch length is set well above the zero (which means it sews in place)? Perhaps the presser foot pressure is set too firm and is preventing the fabric from moving under the foot.
May 17, 2017 | Elna Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
How is a pressure foot shank removed from a Elna 9000
There is a flathead screw on the left side of the shank, unscrew it and the shank comes right off.
Jul 18, 2014 | Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
I have a ELNA model 1010 and there seems to be no tension when do a test strip it bloobs up
Try re-threading the machine with the presser foot up.
This opens the tension and allows the thread to "seat".
Thread with the presser foot down and the tension is closed and the thread cannot seat.
Mar 07, 2010 | Elna 1010
I have inherited this machine and when I try to embroder it gives message remove presser foot
The presser foot may need to be removed or adjusted. For more info on that check here:
http://northernlightdesigns.com/fun-with-sewing-machine-feet
and feel free to ask any other questions you may have.
Nov 12, 2009 | Janome Memory Craft 9000 Computerized...
Pressure foot on Elna Diva
Make sure your presser foot is in the lower position. Open the door on the left and it has 3 settings. You may have moved it up for sewing something thick, and forgotten to lower it again. Sometimes things are simple, though your problem could be mechanical.
Jan 17, 2009 | Elna Sewing Machines
Sewing Machines Logo
243 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
