Question about Sceptre Televison & Video
How to fix hdmi ports on Sceptre tv
Its a great tv and it would be great and really convinent to have the HDMI working again
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
dsacco86
  • 1077 Answers
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Posted on Jan 29, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
crapiemael
  • 241 Answers
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Posted on Jul 21, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
All four HDMI ports on my LCD TV failed all of a sudden, but VGA port still works. Why?
Corrupted firmware. A firmware update might be necessary. Contact the authorized service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 09, 2014 | Sceptre Televison & Video
TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Mar 26, 2014 | Televison & Video
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Sceptre HDTV HDMI ports won't work?
Make sure you are on right input. On your remote press input until you are on the right one.
Apr 26, 2017 | Sceptre Televison & Video
Both HDMI ports are bad due to lightening strikes. What do I need to do to fix this? Can you suggest part numbers?
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Aug 03, 2011 | Sceptre X42BV 42 in. LCD TV
Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Oct 17, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Jun 09, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Televison & Video Logo
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
