Question about Gerber Blades Gerber Ultra Flush 14" White Elongated Two Piece Pressure-Assist Toilet 21
It has pressure, but its pushing water out into the bowl instead of down. Whats the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 245 Answers
Take cot hanger Polk it in the hole,s all round it. Polk where you Se the water coming out.this works for the ordinary toy-lit.you may have a obstructed in the out flow that you cont Se .
Posted on Feb 15, 2012
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
50 year old American Standard toilet . Bowl fills up ,makes noises like it's pluged & then flushes
You have a blockage in the trap as the water goes out . What happens is that there is so much pressure with the water building up in the tank,, that it finally pushes the water out. Also check the vent above the toilet which is located on the roof. It must be free of debris to allow the pressure to stay equal and not a vacuum.
Feb 18, 2013 | American Standard Traditional Champion4...
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Water pressure too much with PEM 070
a device called a flow restrictor is needed in this case , pond supply places can source this device as it needs be sized for the size of hose your using
May 10, 2012 | Little Giant Garden
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
My mothers toilet will not flush, its like theres no suction, when flushed the water in the bowl goes down very slowly but not all the way down to the hole and when it does its very slow weak suction. I...
Try getting a bucket full of water and dumping it pretty rapidly into the toilet bowl. This is essentially what happens when the toilet is flushed normally, but it removes the variable of how the water is being delivered from the tank to the bowl. It should swirl and go charging down the drain, quickly leaving the bowl with very little water. If it does not act that way, then problem is definitely that the drain is obstructed. When you snaked it, you probably used a fairly short snake (about 10 feet?). Try a plunger - use a good one not the kind designed for sinks. Flush multiple times and get vigorous with it. If that doesn't clear it you will have to remove the toilet and use a much larger and longer snake (50 ft or more). good luck, Al K
Dec 31, 2010 | Home
TOILET WONT FLUSH AWAY PROPERLY
I believe what your plumber was referring to are the flushing orifices. Yes they have changed through the years. Unless you have a pressure assisted toilet, the orifices are what makes it flush, by breaking the trap seal and creating a vacuum. Now that being said you can check to see if this is the problem by filling up a bucket with aprox. 2 gallons of water and dumping it straight into the bowl. It should flush right down with out hesitation. If it does then your orifices are not working properly. If this is a new stool, it is possible it is just a bad mold and should be replaced. I hope this helps. Your new toilet should flush for you.
May 08, 2010 | Home
Hi, my halstead ace high boiler has started losing pressure and when i top it up to put the heating on after 10 mins the pressure is high whats wrong with it?
Probably a waterlogged expansion tank. The tank provides a springy air cushion for the water to push against as it expands, and the air pushes back as the water contracts. This scheme minimizes the pressure change that would otherwise be caused by expansion and contraction of the water, giving the water somplace to go when it expands. If the air cushion is gone ... big pressure swings.
Dec 28, 2009 | Water Heaters
Gerber Blades Gerber Ultra Flush 14" White Elongated Two Piece Pressure-Assist Toilet 21 Logo
196 people viewed this question
Top Gerber Blades Home Experts
john h
Tom Chichester
Are you a Gerber Blades Home Expert? Answer questions, earn points and help others
