Question about Car Audio & Video
Can't change the bass level on a Kdc bt6544u?
All I have when i press down the audio button is subwoofer, please help
5 Suggested Answers
  • 132 Answers
SOURCE: Adjusting balance on Kenwood KDC-3024 CD player
AM, FM
And Left and Right Track Select
Posted on Jul 30, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
Posted on Sep 14, 2009
SOURCE: i need to put the subwoofer levels in the radio
go to standby mode. then hold your bass boost button in and the menu should pop up. scroll through until you find th aux setting and use your volume control to set it to on. then the option should be back.
Posted on Oct 02, 2009
  • 5476 Answers
SOURCE: I bought a car with a KDC BT945U Audio Radio, but
The manul for the KDC-BT945U is available from Kenwood: http://www.kenwoodusa.com/Car_Entertainment/2010_Car_Entertainment/KDC-BT945U . Click on the Manuals tab. The direct link to the English version of the manual is http://manual.kenwood.com/files/4c3ba7ba66e53.pdf .
When Protect is blinking in the display, there is a short circuit in the speaker wire. Make sure that it is correctly installed and that the wire is not touching the chassis. Insulate the wire if needed. Then press the Reset button which is on the front of the main part of the unit (rotate the faceplate down) on the left side. (It's about where the source button is on the faceplate.) See page 70 of the manual for the wiring diagram and page 4 for a picture of the Reset button.
If the Protect message continues, you need to take it in to a service center.
I hope this helps.
Posted on Oct 08, 2011
I have no idea how to set the time for my clock on my kdc mp335 cd player
i was in a similar situation today luckily i was able to figure out the solution
follow this
1.switch to STANDBY MODE using the power button on the remote or using the SRC button on the player itself
2.Once you are in the standby mode , press the MENU button ( bass button ) on the left hand side top corner for 1 second
3.Use the right control Knob up and down to switch to CLK ADJ mode .
4.Once you are in CLK ADJ mode Hold the right control Knob for a second until the time starts flickering for change
5.Use the right control knob to change the settings , up and down changes the hour and , left and right changes the minutes
6.Press the MENU button ( bass button ) to save and exit
7.ALWAYS MAKE SURE YOU ARE IN STANDBY MODE
hope this helps :)
Aug 20, 2011 | Kenwood KDC-MP335 CD Player
How do i turn on the subwoofers through my kenwood radio model number KDC-MP142/CR it said to hold the AM- button for 2 seconds i did and it did not turn them on and it does not show subwoofer levels or...
According to the manual you need to hold down the source button to enter audio control mode.
Hold Source button
Press audio knob to enter control mode
Select audio item to adjust (scroll to what you need to adjust, then press the audio knob)
Adjust, turn on what you need
To exit hold audio knob for a second
Sep 21, 2010 | Kenwood Car Audio & Video
Not clear on how to search and store radio frequencies manually in my Kenwood kdc-bt6544u car audio player. can i jump to a specific time in audio or do i have to hold the FF or RW till i get there? not...
Some makers are different.Usually if you hold down the search button long enough,it will switch to autosearch.There should be numbered buttons on the face of the stereo too right?Tune in to the channel you want to preset,press and hold down the number you want it to be.The sound will probably cut out for a couple of seconds,then when it comes back on the channel is preset.Once you set 6 on FM,if you press the band button again,it should give you the capability of presetting 6 more.If it goes to AM just press band once more and it will give you 6 new FM.Usually current radios give 6 AM possible,and 3 separate bands of FM for a total of 18 FM possible.Good luck! Greg
Aug 16, 2010 | Kenwood Car Audio & Video
I've been trying to figure out how to adjust my sound because ever since I got the KDC MP642U my bass has been nearly non existant. I looked in the manual and it says to go to the sound category to adjust,...
You've probably figured this out by now, but you are supposed to go through the FNC button, click the control knob left, scroll down to SOUND, click and it will show you a menu with Control, Setup, and Preset, etc., and under the Control will list the EQ, bass boost, and highway sound. Under Setup you can adjust the frequency sensitivity under the X-Over option, the type of cabin, location of speakers for central sound, it's all there. Also, on the main display, if you hold the volume knob down for a second, you can adjust the dB level. If still nothing, check if the sub is on. On the main display, hold down on the control knob for two seconds, if will toggle the sub on or off. One thing I'm stumped by however is that I am either getting no subwoofer output, or just any amplifier output at all when trying to use the aux source and the USB source. I had gone through all these settings under each source, i still got nothing. I would assume that this can't not be an option for these sources. I need help.
May 23, 2010 | Kenwood KDC-MP642U
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
Subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
Sep 13, 2009 | Kenwood KDC-138 FM / AM Receiver
I need to put the subwoofer levels in the radio
Jun 07, 2009 | Kenwood KDC-MP335 CD Player
On my Kenwood kdc-mp339 car cd unit unit I cannot disable the demo feature that scrolls across the led face as it says you can in the manual. Cannot get the option to disable demo , Thanks for any help
Just figured it out - you have to put the player in Standby mode (by pressing SRC till you find it) first.
Then hold down the bass boost button (as the manual says). When MENU pops up, scroll down to DEMO ON and then hold down the centre button of the conrol knob till it changes to DEMO OFF.
Jun 21, 2008 | Car Audio & Video
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
