Question about Panasonic Televison & Video
Panasonic TV - model TCP42X3X - How can I disable the
Every time one clicks the input button, an OSD shows up allowing one to choose input. How can I disable this feature and just press input to go to the next available input?
SOURCE: Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Posted on Feb 18, 2008
mistersony
  • 320 Answers
SOURCE: OSD on Sony Bravia
Depending on the models of your units, there are some software/firmware upgrades for specific units to adresss this particular problem. Check the Sony website under support to see if any software/firmware upgrades are available.
Posted on Oct 19, 2008
gripfitter
  • 557 Answers
SOURCE: Panasonic Plasma TV - Model # TH42PX77U does not
This is a difficult question to answer completely. 7 blinks indicates that one of the C boads has failed. however, there are several an SC,SD, SS and SU.
The procedure is to disconnect each of there boards until the blinking is eliminated. The labor charge is usually around 200.00 and the cost of whichever board is bad. Hope this helps.
Posted on Oct 21, 2009
  • 1779 Answers
SOURCE: Osd time out?
OSD= On Screen Display. That feature keeps the information such as channel,time, ect.. for a length of time that you choose in the menu on the screen. Some sets let you change the color of it and also the background.
Posted on Nov 10, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Posted on May 02, 2010
How do I hook up my blu ray to my floor model panasonic tv
You can use an HDMI cable if both your tv and Blu-ray player have that imput. That will give you the best picture and sound. Both video and audio are carried through the one cable. Next down in quality are Component cables. You may need to use these if your tv doesn't have an HDMI input. These 3 cables are red, blue and green. They will give you the picture but no sound. This is normal . All component cables need red and white composite cables for audio. When you have made your choice of HDMI or Component, click the input button on your tv remote and scroll down to either HDMI 2 or 3 or 4(if you used an HDMI cable) or choose "component" to allow the signal to come through. Make sure you at least have the blue-ray player on so that when you do see it on the screen, you'll know which input you chose to get it to come through. Remember, after watching your Blu-ray, remember to turn your input back to your cable setting so you can watch tv again
Dave
Jan 28, 2015 | Panasonic Televison & Video
OSD menu locked
When the OSD is locked, pressing the menu button again and it will take user to OSD LOCK menu. Press (+) to unlock and allow user access to all applicable settings.
Aug 12, 2008 | Dell W1700 17 in. HD-Ready LCD Television
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
Panasonic TV - model TX29fg50A - How do I get rid of the OSD channel indicator in the top left - always shows AV1.
check the control button first if they are operating properly..then check for loose colder connection before suspecting the control ic
Jul 15, 2011 | Panasonic Televison & Video
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Show "OSD Locked".in that cause i-Menu is not working. what i do?
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
HP L2035 OSD Lockout and DVI lockouts
change micro switch in frount panel all
Mar 19, 2010 | HP L2035 20.10" LCD Monitor
The OSD on my Harman/Kardon 347 does not show up anymore. I am using a Compostie cable and it just stopped working a while ago. I had hooked up an X-Box 360 to my T.V using the 3 RED, GREEN, BLUE component...
Put the receiver in stand by mode (amber light) and hold on the tone button for 8 seconds. This will reset the receiver. After it says reset, let go of the tone button and wait about 30 seconds. Then hit OSD and you should be good to go.
Jul 22, 2008 | Audio Players & Recorders
Televison & Video Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
