Question about Mx Drills
Schneider electricI need a 24 volt charger for model cdd240t9cd can you help?
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Need a charger for 24 volt B&D fire storm--
the charger you need is PS1MVC and you can buy it online from Blackanddecker.com if not look in you local phone book for tools and you might be able to get it from a big box store like Home Depot. Let me know if you need any more help
Posted on Oct 25, 2009
Has anyone a circuit diagram and possibly information about the transformer output voltages for a Pihsiang mobility charger model MB-24/3 battery charger?
Hi again i have no data on Ac voltage output AT A GUESS I WOULD THINK IT WOULD B APROX 35 TO 38 VOLTS one thing i did find u can still buy them at MONSTER SCOOTER PARTS ITEM NoCO4-1179 PRICE $183-99 PHONE NUMBER 800-798_0325 GOOD LUCK. input : 100-120 VAC, 50/60Hz 1.5 AMP. U CAN BUY NEW ONE'S ON E/BAY,,..hi output is 24 volts 3.0 amps hope this helps..........
Dec 11, 2015 | Health & Beauty
Looking for a 24 volt charger for Ryobi cr24re
Here's one for $21.99
You can go and search more of ebay and find a better deal i'm sure. RYOBI MODEL OP140 BATTERY CHARGER 24 VOLT
Have A Good Day
Nov 11, 2014 | Ryobi Drills
How to fix a 24 volt black and decker battery charger
You need to post MORE information like what is it doing or not doing and how you use this charger then we can eliminate operator trouble and focus on the charger.
Jun 17, 2014 | Black & Decker Black And Decker FS24C...
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
Trying to find battery and charger for Worksite Cordless Drill, Circular Saw and Lamp (flashlight). Model nos. on all state CT120-C. Voltage is 24 volts. Made in China. Can you provide any help on find...
I also have the CT120-C set, with the 24 V battery, but alas no charger. Been searching web with no luck. Have you found any links where you can buy it? If so, please let me know at gurven@gmail.com...
Aug 04, 2011 | Vacuums
I have a JET Mobility Model 2904JT-24 Battery Charger that I would like to use to charge a 24-V project I'm working on. It's from a Pride Jet 2 HD. Trouble is, I only have the charger (no wheelchair) and...
Blue Positive Brown negative, Yellow with green stripe is additional ground. many people are trying to use the 2904JT charger for a 24 volt charger for other things. I am using mine on an e bike that has 4 12 volt batteries. I charge them 2 at a time and it works well. It only shows voltage when the batteries are partially charged. Some kind of safety feature to keep you from charging a shorted battery. No schematics available, I took my chances and verified the Blue wire is positive. lol Good luck with you project or re wire. : )
Jan 24, 2011 | Pride New Mobility Victory XL 4 Wheel...
My charger is not putting out dc voltage, but is putting out ac voltage. for example, if i select 24 volts it will put out 24 volts ac, not dc. what failed to cause this problem? I am getting no amps on...
Hi, you're Rectofier has failed if you have A/C voltage and no D/C voltage. This is what converts A/C volts to D/C volts. If you have a diagram or any parts manual, you can locate this part and replace it. You will need to go to a place that repairs these chargers, or where you bought it to order or but a new one.
Sincerely,
Shastalaker7
Dec 30, 2010 | Heavy Duty Associated Equipment 6002B...
I work at a homeless clinic. We had a Jazzy 1170 donated and we charged the battery for about 7 hours. When we tried it out it moved very slowly. Nothing was registering on the amp meter on the back. ...
Yes you probably need new batteries. If you have access to a digital voltmeter set it to 200 volts DC and plug the leads into the charger port located under the front of the joystick. Plug it into the 2 outter holes. Without the charger plugged in you are reading the battery voltage it should read 24- 27 volts. Now plug in the on-board charger and the voltage should go up to 27-30 volts. If you don't get at least 24 volts w/o the charger plugged in then the batteries are bad. If you don't read 27-30 volts with the charger plugged in then the charger is bad and unfortunately both might need to be replaced. Hope this helps
Sep 14, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
I need a charger? Where can I get one?
Walmart or most other stores should carry the proper 24 volt charger that you need. You could also try an electronics store. Be sure to mention what it is for and that it's 24 volts.
Hope this helps.
Sep 22, 2009 | Mini Battery Operated Racer Yellow
My chair wont charge in either of the charging ports
It's either a dead charger or dead battery(ies). You will need a voltage tester meter to check. First check the charger by setting your meter to a setting over 24 volts (your chair is a 24 volt system). Test the voltage at the charging port by placing the two probes into the two outside ports (there's three ports in a triangle...test the two opposite ports.) You should get a reading in excess of 24 volts but less than 26. Now plug the charger into one of the ports and check the voltage again. If the voltage is now higher than the first reading, your charger is working and you will need to replace the batteries, if it is the same, your charger is bad.
Aug 06, 2009 | Pride Mobility Products New Pride Mobility...
Drills Logo
50 people viewed this question
Top Mx Drills Experts
Are you a Mx Drill Expert? Answer questions, earn points and help others
