Question about Bruder MAN TGA Container Service Truck
I have MAN TGA 18.350 it seems on dash board CHECK TCO wht does it stands for
  • Haroon Feb 15, 2012
    wht does it means
Man tga what is tcu
TCU stands for Transmission Control Unit.
Apr 12, 2017 | Toys
Hello,I have a MAN tga 19.360. It's running code 08108,08112.08104,tco failure n INST failure.key turns on but won't start. What could be the problem?
the code is MAN specific so to get an understanding of what sensor is faulty , go to a MAN service center and ask what it means
Feb 25, 2017 | The Toys
SHOWING THE CODE ON THE DASH BOARDEDC-03775-02
Did you check or replace a high pressure fuel pump ? If you did it and your truck is still under power, try to replace an alternator.
Feb 26, 2015 | Bruder MAN TGA Container Service Truck
TCO 04318-03
Very sorry here but trucks have long evolved since i worked on a M.A.N or a Scania ,come to that even a gardner engined GUY ,in my time you worked from experiance ,even the engine stop was cable and the cold start was on the inline injector pump ,and you could reset the fuel amount with the pump on the engine and the engine running .5 fuel filters on a gardner engine as fitted into a foden ,try de-waxing that in the morning when the temperature was at -14C
Jan 13, 2015 | Bruder MAN TGA Container Service Truck
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Fault code edc 00637-03 on M.A.N.410
Man tga 410 hata kodu 00637-03 nedir bu ? Yard?mc? olur musunuz ?
Nov 10, 2012 | Cars & Trucks
What does the code TCO mean to a man truck
it's mean;to check or changing kilometrage disk paper !!!answer me on: debdou5@hotmail.com
Oct 20, 2012 | Bruder MAN TGA Container Service Truck
COD MAN TGA EDC 03050-03
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
May 07, 2011 | Bruder MAN TGA Container Service Truck
Bruder MAN TGA  Container Service Truck Logo
371 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
