Question about Ricoh Office Equipment & Supplies
How do i remove shadow image on copies - Ricoh Office Equipment & Supplies
    Habit-Forming:
  • 96 Answers
Clean the glass, scanner and if not you have to check both coronas.
Posted on Feb 16, 2012
When copying i have a shadow in background
Check copy life of consumables like Developer and Drum if ghost image might be Cleaning Blade found Imagaing Unit or Upper Fuser at Fusing Unit. If replace the whole imaging unit can solve your problem but individual parts try to clean first imaging include charge roller before you replace drum, cleaning blade and developer. mostly we replace developer only.
Mar 06, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
Tip
Shadow in the image
If you see a shadow in the lower part of your image when shooting with the built-in flash, it's probably the shadow of your lens hood.
Try removing the lens hood. If that doesn't work, perhaps the lens is too long/big: consult your manual: the manual should tell you which lenses cause shadows. Otherwise, try using a shoe-mount flash or off-camera flash.
on Dec 18, 2009 | Cameras
Shadow copy
Need a little more info but if you are using a laserjet printer shadows or duplicate images usually come from worn out rollers in your fuser. Depending on your model fusers are available by themselves or as part of a maintenance kit. Replace the fuser and that should take care of the problem.
Nov 02, 2013 | Sharp Toner Digital Copiers Ar M355 M351...
Alignment is not the issue with my printer... i keep getting a shadow behind my letters and images I print, but not on typed documents... only scanned ones or copied and pasted images into word... so...
The shadows are common from scanned images. You might want to hold the book you are trying to scan in a better angle so that the scanner can read it more clearly. Then your scans won't have that many shadows.
Mar 06, 2011 | Office Equipment & Supplies
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
"shadow" copies
is the shadow off set from the original image?
if so it could be the cleaning unit for the fuser (heater) may have to be changed. If the cleaner does not clean the fuser rollers a residual image will be passed onto the page.
Apr 15, 2009 | Sharp AR-M237 Copier
Grey marks and shadow images on copies
Drum, cleaning blade, and PCR need replacing, and most likely the developer as well. This is not something that can be done by an end-user. Fuser could be causing a portion of this problem as well. The machine basically needs it's 60K maintenance performed.
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
SAVIN NOT MAKING CLEAN COPIES
I don't know what model you are referring to, but regardless of that, you have a drum cleaning, and /or worn fuser roller problem
Mar 18, 2009 | Office Equipment & Supplies
Double shadow image
YOU NEED TO CLEAN THE LASER UNIT happy faxing omnipresent
Oct 01, 2007 | Canon FAXPHONE L170 Plain Paper Laser
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
