The heater has stopped working. Fan just blows cold air.
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.------
Engine
Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
---------Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Did you drill by the passenger side to put mud guard? I did drill into the vacuum reservoir, and it went into default blowing cold air up the windshield check vacuum lines first.
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level.
SOURCE: heater blowing cold air Buick Century 2000
does the car not heat up in general? Whats the temp gauge doing and how long of a ride have you tried this for?
SOURCE: Blowing cold air ,no heat
Not exactly certain, but sounds like you have a broken "blend door" or acuator malfunction
SOURCE: blowing cold air via the heater
Assuming that none of the Electrical/Electronic controls were disturbed when changing the Thermostat it seems to me that you have an "Air Lock" within the heater. One must purge all the air out of the cooling system as close to the highest point as possible after the system has been partially or fully drained. Most of the time one will find small BRASS Bleeder Valves located somewhere near the highest point. Open each one while the system is pressurized and let Air escape until some Coolant escapes. Sometimes it may be necessary to loosen a Heater Hose and bleed the air at that point. Remember that the system MUST BE PRESSURIZED to accomplish the Bleeding of Air. Many auto parts stores sell hand pumps with a pressure gauge for this purpose and leak testing. These pumps typically replace the Radiator Pressure Cap temporarily. The system does not have to be at normal operating temperature to bleed the air out. Once the Air has been bled you will have to refill the radiator to normal full and make sure that the Coolant Recovery Tank level is also brought up to recommended level. A quick check is to remove the Radiator Pressure Cap, Start the Engine, Rev the engine suddenly (A short Jab) and see if the coolant level falls rapidly in the radiator. If it does it is definitely an AIR LOCK situation.
Fastest Robe
Testimonial: "Thank you, I'll do the quick jab test to determine the air lock and proceed with bleeding"
SOURCE: 1997 buick lesabre HEATER PROBLEMS The fan
This could be several things. First I would check that the thermostat is not stuck open. This will condition will make the car run cold when it is cold outside.
If this is not the case........and I'm assuming you've already checked that the antifreeze is full, make sure that the heater valve is working. If it is frozen in place then it won't move and won't allow the warm water to circulate through the heater core.
I'm basing my answers on a standard Lesabre. Yours may not have the standard climate control.
issue.
Engine Overheats and heater
blowing cold?
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
