SOURCE: stop putting out sound to subs
Ok This is a two channel High Current amp. It is stable to one ohm. If the Subs are single voice coil at two ohms the they have to be wired in Parallel that means (Red +) (Black -) are connected to the + and - of another sub and then the (RED +) (Black -) from both go to one output channel of the amp. You pair the other two in the same fashion on the other output channel. If you are getting no output (sound) at all first check if the amplifier is going into protect. (Usually indicated by a red led on the unit. If it is connect only one Sub to each output and see if the protect LED goes out. If it does then you should have sound at the subs. If not check that you have the sub output enabled on the HU some head units do not come with the sub output enabled on the HU. If every thig is enabled, with only one sub connected to each output and the protect LED is not on then your amp is probably blown and needs repair. Nice thing is that MA has a great warrenty policy. Check and make sure the protect LED is off. If it is on you probably have the SUBS wired wrong
SOURCE: is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it? Let me know if you wish. Otherwise
