Question about Coship Televison & Video
HOW DO REPROGRAM COSHIP CDVBC5120 RECIEVER
USED WITH MESH AIERAL IN SPAIN COMPANY PROVIDING SIGNAL GONE BUST CAN I PICK UP ANY OTHER SAT FOR FREE
2 Suggested Answers
  • 212 Answers
SOURCE: can i use my freeview tv reciever box i bought in
If it can pick up the signals, then yes. You'll need a mains adaptor....:-)
Posted on May 04, 2010
I have a technomate tm 1500 sat box . This is used in Spain if I buy a new tv in Spain will it connect up ok ?
Kindly study the operation manual, then check what is the format used there in Spain, like PAL/Secam etc. and ensure compatibility.
Jul 30, 2012 | Televison & Video
What to do when television sound doesn't match the picture.
Unplug your sat/cable box wait a minute and then plug it back in. If it continues or restarts you will have to get the Sat/ Cable company to change your reciever. I have had a problem with it with Dish Network. Has not happened since reciever was replaced.
Dec 15, 2010 | Vizio M190MV 19 in LCD TV
On my 322 DTR I get a Sat 1 no input even when I swap the 2 input cables. Input 2 shows ok
Hello, Daniel Busa here with Dish Network customer service. It sounds like your signal input on your reciever may be fried. You will probably need a replacement, one thing you can try is replacing the separator that runs to the sat input 1-2. This may be the issue as the ports are rated differently if you pick on up make sure it's rated at 2,150 mhz.
Nov 16, 2010 | DISH Network 322 DTV Receiver
My model is Coship CDVB2000 digital satellite receiver now signal power is 160 but no green color signal quolity is 0. We do not receive tv signal
Hi: I have a used one, which is in good condition. tell me if you are interested. - Jack - E-mail: cctvpro@yahoo.com
Jul 17, 2010 | Coship CDVB2000E
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Glass reinforced concrete composite stone table broken
Believe it or not Gorilla Glue holds that sort of thing quite well. You may have a visible line, but not too bad providing you keep the pieces held together tightly for an hour or so (it foams and expands -- scrape off the excess after it dries.) I would also get some epoxy (the thin stuff, not the putty stuff) and some fiberglass mesh and reinforce the bottom. Something else -- some contractors who do foundation repair have an epoxy and carbon fiber mesh that would do that and be indestructible -- see if you can find one in your area. I could give you someone in my area, but that probably wouldn't help you. You'll have to call around. If you can't find it, the fiberglass mesh is used in boat, RV, and tractor trailer repair so one of those shops should be able to sell you some.
Nov 02, 2009 | Welding Tools
The TV loses the signal from the dish reciever. I've checked all connections. I have to turn the TV off and then back on to fix it.
since you have a dish reciever you could try connecting the dish box to the television with the AV cables.. (yellow, white and red cables) to the television. once that is done press the source button on the remote until it displays composite then you will have the picture from the sat box. Try it like this to see if it still loosing the signal..
Also you could try is turn off the sat box then back on and see if that fixes that problem if it does could be something wrong with the sat box.. also test a dvd player to see how that reacts.. if that plays good and you connect the sat box on that same connection then the sat box could be having some issues.
Jun 21, 2009 | Olevia 237T 37 in. LCD TV
Televison & Video Logo
256 people viewed this question
Top Coship Televison & Video Experts
Electro Med Services...
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
