Question about Armitron Watches
Change battery 20/4665sv gm00
How do you change battery
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
Hello, here's a video that provides straightforward, easy to follow steps on how to change a watch battery. I ...
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...
How to Change a Watch Battery: 13 Steps (with Pictures ...
Dec 15, 2015 | Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
Jun 14, 2010 | Fossil JR8096 Wrist Watch
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
Nov 25, 2009 | Kenneth Cole KC2315 watch
Battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
Jul 29, 2008 | Adidas Watches
Softwatch by Exaequo
call 973 444 7400 solve all watch &parts problems
Mar 20, 2008 | Watches
Watches Logo
85 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
