Question about Makita Drills
Why does my Auto Feed Screwdriver not screw deep enough?
Despite setting the bit to protrude at its maximum (7mm) the screws do not drill through plasterboard and into the timber flush, but stand proud. How can this be remedied?
  • mrs_lindamar
    mrs_lindamar Feb 19, 2012
    Turned out that the machine was set on reverse! Every other drill or screwdriver I have used which has the "reverse" button on the handle like this, you press in the left hand part of the switch and pop out the right hand side to drive forward, and vice versa. With this Makita you need to press in the RIGHT hand side of the switch and pop out the left to drive forward. BEWARE - THE REVERSE SWITCH IS OPPOSITE WAY AROUND TO NORMAL DRILLS!
  • mrs_lindamar
    Many thanks for the attempt to help me solve the problem - but it was something other than setting the depth wrong, etc.. Just a machine which has its reverse action opposite was to all other machines!
  • Makita Master
  • 885 Answers
What model auto-feed screwdriver do you have? All of the auto-feed drivers I have worked on have an adjustable nose peice that has to be set to the length of the screw so they will start properly and drive correctly. They also have a fine tune adjustment wheel somehwere on the tool so you can set the screw to be anywhere from just below the surface (dimpled) or flush or slightly above the surface (proud). This is all in relation to the surface the nose peice is touching. The driver is designed to release the bit when the screw has reached the depth set by the adjustment wheel so it doesn't strip out the head of the screw. I don't know of any that would let you set it so the screw would go through the plasterboard (drywall) and end up flush in the wood.
Posted on Feb 17, 2012
How do I fix my ceiling that has fallen down
If not too bad, it can be re-nailed or re-screwed (easier) to the ceiling timbers, and the fasteners plastered over.
If bad,it is best to pull down the whole lot (take care, it is heavy), examine the ceiling timbers for termites or rot, and then replace the ceiling with plasterboard (drywall), and new cornices.
Aug 09, 2016 | Dryers
How to put a raw plug into a plaster wall?
It's actually quite easy, but a few simple rules need to be followed. The drill size will depend on the size of the plug to be used. The type of drill bit will depend on whether it is a wall with plaster on it or plasterboard, which will have a cavity behind it. If it is a solid wall, use a masonry drill, on hammer setting if you have it. For a plasterboard wall a wood or HSS drill bit will do the job. Once you have drilled the hole, push plug in as far as you can, then tap it flush with a hammer. Job done.
May 20, 2014 | Hand Tools
Broken screw on oven door means we cannot change the hinges
Without seeing how or where the screw is located the Idea below may work. I assume, what is left of the screw head is flush with the hinge. See if you can get a drill bit on top of the screw. If so start with a drill bit smaller than the outermost edge of the screw head. Drill slowly until the head of the screw is gone. You can always start small and work your way up to a larger bit. Do not drill into the hinge. Now that the head of the screw is off, you should be able to lift the hinge off. You will now have the shaft of the screw sticking up. I would spray the saft with a penetrating fluid or wd-40. Let it sit in. Then take a pair of locking vice grips and lock on the remanding part of the screw. Now you should be able to turn it to the left like a normal screw.
If you somehow brake the screw off flush with the frame then youll need to use an easy out.
Nov 29, 2013 | Maytag MEW5527B Electric Single Oven
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
Im looking to mount my TV to my wall and wanted to know what size screws to use?
This will depend on what type of wall you are fixing it to. It's a pretty big TV so for a solid timber brick or cement block wall I would suggest M5 or M6 x 50mm
If it's a hollow stud-work wall you will need to use specialist hollow wall fixings such as toggle bolts. again M5 or M6 thickness would be appropriate but you would be well advised to try to screw into the actual stud-work rather than just rely on plasterboard to support such a weight. You can buy an electronic stud detecting tool from DIY stores relatively cheaply.
Feb 25, 2011 | Panasonic TCP42C2 42 in TV
Correct clutch setting for driving screws
This depends on the softness / hardness of the timber you are driving the screws into.
Start with midrange clutch setting and when clutch slips, adjust the setting upwards until screws are driven fully home.
Feb 18, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
Will this drive half inch rebar through 12 or more inches of landscape timber in a retaining wall?
Yes, but I usually drill a hole just a bit smaller then the rod so that the rod does not split the landscape timbers....
You can buy ship auger bits up to 12" long and they drill through the landscape timber fairly well...
heatman101
Nov 22, 2010 | Bosch HS1924 Sds - Max Hammer Steel Ground...
I brought vespa lml 04 plate of lad that put a 180 malosi kit on got good comprstion great runner when running but night mare to start have to kick start for ages and wont start with air filter on once got...
Try turning the idle screw which protrudes from the air filter box anti clockwise once it's running. Or try taking your air filter off and drilling two holes (5mm + 7mm) in the little 'heart shaped' depression on the bottom of it.
Jun 10, 2010 | Peg Perego Vespa Scooter
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Using a bosch psr18 power drill
Hi, they usually list the torque to screw size ratio in the instruaction manual. If you cant locate yours many companies list their instruction manuals pn the web on their home page, or you can sneek a peak at a hard ware store on a similar drill.
The usually rule for small screws is torque 1-4 on small screws.
Otherwise practice makes perfect & different types of timber will affect when the torque kicks in.
I still believe that an impact driver is better than a drill with screws as it impacts the screw in & this gives you better control. It will actually slow the screw down & you can recess it just perfectly. The drawback is that it can snap small screws when driving into soft timber. (but you can always predrill)
cheers
Laurie
Sep 10, 2008 | Bosch Drills
Drills Logo
134 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
