Question about Homelite Garden
Primer bulb for a model uto8550a blower - Homelite Garden
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
It sound like the primer bulb does not retract by itself due to aging problem.
Posted on Jun 18, 2009
  • 148 Answers
SOURCE: Won't start
Have you tried cleaning the carb? If not take some carb cleaner and spray into the carb inlet and outlets (gently inserting the nozzle). After that see if it will start.
Posted on Sep 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 3 Answers
SOURCE: primer bulb is cracked on my Homelite Blower/VAC
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Posted on Apr 30, 2010
After replacing primer bulb, engine hesitates and will not run full throttle
Make sure you connected the lines correctly. If this is a primer assy that has the 2 barbs on the back here is a picture of how the lines should be connected to it as well as the carburetor
Now if this is a primer bulb on top of the carburetor then disregard the previous answer because in this case, your carburetor needs the H needle adjusted. Go on you tube .com and type in how to adjust a 2 cycle carburetor. Many videos will appear.
Nov 21, 2015 | Garden
How do i change the primer bulb on a toro model #ccr2450 snow blower
most primer bulbs are held in place by a metal ring plate with either 2 or 4 screws
remove the plate and the bulb will fall out
make sure that the molded edge of the new bulb is correctly fitted into the groove in the body and refit the plate and screws
Sep 06, 2015 | Toro Ccr Snowblower
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
No fuel in primer bulb on my echo PB 2100 blower
The primer bulb pulls fuel from the carb into the bulb and dumps back to the tank, so either the tubes are not connected too the correct conections on the carb, or there is bno fuel getting to the carb from the tank ( fuel filter ) or if the primer is on the carb itself there in a red one way valve under the bulb which maybe faulty.
Jun 16, 2012 | Echo Pb-2100 Pb 2100 Leaf Blower Inner Fan...
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
I can start it, but it shuts down after a 10 seconds
The model number for your post is for the blower attachment. Can you pass the model number of the upper assembly please so we can better help you. Thanks
Kelly (cont below)
I am going to go out on a limb here.. Most of these troy-built trimmers use this carb with primer bulb.
PN 753-1225
http://www.ereplacementparts.com/carburetor-with-primer-p-283336.html
What usually happens to them is the primer bulb on the bottom of the carb gets a pin-hole in it and then air is drawn into the carb vs fuel from the tank.
You can try to get just a primer bulb at your local lawn mower parts supply. You may just have to bite the bullet and replace the whole carb.
Apr 19, 2010 | Troy -Bilt String Trimmer/Blower...
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
