Question about MSI Computers & Internet
Need a new or recondtioned internal sata hard drive for msi wind dx135
Crashed netbook took it back to default settings lost everything including windows now all it says is disc loading error with blue screen someone said its my int hard drive not got money to buy a new lap top so hoping if i change hard drive it will work and be cheaper
  • 85 Answers
That's correct the is going to be no problem at all to install a new HDD inside of the netbook will be like any other computer so parts are exchangelable, so don't worry just make sure to buy a HDD that matches the space inside of you netbook, and make sure that if you're installing the HDD on your own, to take a look into where's the HDD connected they usually have an adapter to plug them in. Best regards, Luis!
Posted on Feb 17, 2012
2 Suggested Answers
Morfi717
  • 88 Answers
SOURCE: msi netbook reset
Not that complicated:
1. Enter to BIOS (when PC bootup try to hit F2 or F10 or DEL, it will show which is correct but you may just hit all of them)
in BIOS you will find tab and option "reset to default"
2. Then about the HDD, just install new system on it (XP, Vista, Win7, whatever you wish)
Cheers,
Mike
Leave rate if I helped you, thanks!!
Posted on May 08, 2010
PXE-E61 Media test failure, check cable
YOUR NEW HARDDRIVE SATA THEY HAVE A BAD SECTOR. UNEED TO CHECK DISK TO OTHER COMPUTER OR HDD REPAIR FOR FIXING THE BADSECTOR THE ACCESS UR HARDDRIVE. TTHEN PUT BACK TO YOUR COMPUTER AND THEN TRY TO PORMAT AGAIN IN XP OR OTHER WINDOWS OS.. TRY TNX
Nov 18, 2013 | MSI Wind U123-002US Netbook
I have a msi netbook u100 series and everything working been restored to factory setting and no matter wht i try i cannot connect to my wiifii router i have the new superhub from virgin and my lappy w
if you look in device manager under network and check if your wireless card has any problems.If you have restored your laptop you may need drivers installing.
Aug 01, 2012 | MSI Wind U100-280US Netbook
Hard drive replacement
wear an antistatic earth strap remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
utube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
hope this helps
Jun 12, 2012 | MSI 320GB Hard Drive for Wind U100, Wind...
I HAVE MSI NETBOOK WITH window xp installed on it but it is not working (window xp) and i can,t reinstall or recover window pls help me
USING THE Installer of your XP installer to portable dvd drive it still not working to reinstall the windows. the problem of your msi netbook is the hard drive. may sulotion for that. used desktop CPU and put the harddrive of your msi and into the CPU of desktop. then Checkdisk your hard drive.
and after that finish the checkdisk. get your hard drive and put again to your netbook. and try to reinstall then XP.
thnx i hope am i share my knowlage
Jan 20, 2011 | MSI Wind U123-002US Netbook
U100 msi wind netbook, webcam problems
You should be able to start the device with a default windows driver. Open windows explorer. Look at the left FOLDER pane. Under My Computer you should see USB Video device. Select it to start the webcam with default drivers. This confirms the device as working. Now, loading the correct drivers will give proper resolutions and other device-specific features of the device.
Jan 08, 2010 | MSI Wind U100 Netbook
Msi virtual built-in camera lost and im using
1. if the problem happened recently try to do a system restore to go back previous to when the problem started.
2. check device manager, find if there's any ? or ! yellow marks next to what looks like your camera, open the properties of the device (if it's showing) and post back with the status info, , you may need to reinstall the driver or update it. post back with our model number
Jan 02, 2010 | MSI Wind U100 Netbook
My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Nov 19, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Mar 12, 2009 | Intel Motherboard
Computers & Internet Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
