Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will only run on choke - McCulloch 16 Inch Gas Chain Saw MCC1635AK
  • McCulloch Master
  • 2,239 Answers
Its running too lean, start with easy stuff first, replace the fuel filter in the tank, check the condition of the fuel hose up to the carb, any signs of damage or leak, then replace.
Posted on Feb 16, 2012
Mine starts, runs 5 minutes, tries to die, runs 5 more minutes (poorly) with full choke, then dies. Carb? Cool?
need vehicle make and year. "Full" choke will always flood the engine causing it to dye. once running reduce choke. Is this automatic or manual choke?
Apr 07, 2017 | Garden
My 2000 kawasaki zrx 1100 will crank an run on choke but die when I take it off choke
If you have a choke you have a carb(s). If it will only run on choke the low speed circuit is likely dirty/plugged. If it will run at medium or higher throttle on choke only you may have further carb pluggin gproblems and/or a plugged fuel filter or pinched line etc.
Dec 07, 2014 | 2000 kawasaki ZRX 1100
My hmc green machine 3000ss weed wacker carb needs adjusting it only runs with choke closed
Try cleaning or changing the air filter. If it dirty the engine will not stay running with out the choke on.
Feb 17, 2014 | 2010 Vuka XL 125
Put choke to run it pops put choke half way runs good
dirt or water in carburetor.Choke helps suck more gas in engine to run better.
Dec 28, 2013 | Garden
I have a Ryobi 780r that won't run unless it is on choke. The moment I remove the switch from choke to run it shuts off.
This means you have an air leak somewhere adding more air than fuel with the choke off. With the choke on it blocks off the fresh air coming in and mixes with the maverick air from the air leak. You need to find the leak and fix it or you may damage the unit
Jan 10, 2013 | Ryobi Garden
My honda vtx 1300 will not run with choke all the way in but will run with the choke half way in. what is the problem?
If your bike will only run with the choke half way out it's starving for feul. You have a clogged jet. By choking the bike you cut off the air and allow more feul to run through the carb.
Oct 30, 2012 | Honda Motorcycles
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
May 06, 2010 | Ryobi Backpack Blower 25.4cc
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
PR4 125 Enduro runs on full choke... What do I do?
2000 rpm and I cleaned bottom of carbs. Someone told running them on full choke would foul out plugs.The bike runs but only when I pull choke all the way out.If it only runs with the choke on it might have a vacuum leak or an air restriction which the choke is counteracting. (very lean fuel mix). To locate a leak you could try spraying CRC around the rubber carb connections and see if the idle speed is affected.,
Nov 10, 2008 | 2006 AJP PR4 125 Enduro
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
343 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
