Humax PVR 9200T freezing picture and will not turn off.
Please can you advise about a problem that has just occured? The picture freezes after 30 secs from boot up and I am unable to turn off the PVR at the front switch, nor can I use the remote control either to record or to change channels etc.
Humax have been 'deafening in their silence' in response to my intial enquiry to them. The PVR will be 3 soon.
I did a Google search for this web page.
Thanks in anticipation
Nigel Bennett
  • 3 more comments
  • Anonymous Nov 09, 2008
    Exactly the same problem. My machine is about 2.5 years old.
  • Anonymous Nov 13, 2008
    Same here, was rock-solid on the old firmware. Did the upgrade early on this year and it's been like this ever since. Will lock within 30secs - 1min when coming out of standby and requires a hard power off/on to rectify. Very miffed.
  • Anonymous Jan 16, 2009
    I have the exact same problem, but the solution posted is no use as the box freezes within 3-6 seconds of the boot completion, so using the remote to reset is not an option.
    Any ideas to get round this problem would be gratefully received, as i have a wife who's at my throat to get this solved.
    Tony
  • Anonymous Feb 25, 2009
    as above.
    the 2 reset solution seems to work.  Box was a bit sluggish after but seems to have recovered now (prob downloading the EPG).
  • Anonymous Mar 22, 2014
    Ultra plus F-9000HD PVR
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Posted on Dec 14, 2008
Why does my pvr have poor signal and freezes or lags
Hello is the tv set connected to the PVR with a coax cable, and has this problem ever occurred before or did it just start happening?
Aug 19, 2014 | Bush 5693D 24" TV
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
I have a LG PC1DV Plazma and every now and then the picture will freeze, the sound continues on and you cannot change channels. the only way to un freeze is to turn off tv wait 30 sec then turn back on and...
Contact your LG dealer & have someone call to check the software version currently used by the TV. It may need updated as there is an issue for picture freeze, if this is ok there could be a problem with the signal strength of your signal, if this drops then it will also cause the picture to freeze, in which case you would need to have your aerial checked.
Dec 21, 2009 | LG Televison & Video
I have a bell 5200 pvr and while watching tv the
Bell sent me two mobel 5200 receivers by mistake. Can I operate them as a single tuner if I only have one line in?
Nov 15, 2009 | Televison & Video
PVR freezes and nowt will work
I'm in the US and am not completely familiar with the digital conversion in your area, but the following information may be helpful to you.
Humax released a software update earlier this year which adds the full range of ‘Group 2' Freeview Playback. For details see Trusted Reviews
Aug 14, 2009 | Electronics - Others
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
TV freezes for a short period of time.
First a couple of questions:
1) What is the make and model please?
2) When the picture freezes, is it like a snapshot photo? or does the screen blank?
This sounds like an interruption in the digital data stream. If the picture remains on the screen, the "new" frame information is not being received nor processed. This can be as simple as a bad cable connection or noise on the digital information data lines.
Check to see if there is any pattern to when this occurs. For example, does it happen more frequently after the set has been on for a while? Try cooling down the set to see if temp effects the behavior.
Please update this and we'll work to resolve it.
Thanks,
Dan
Mar 16, 2009 | Televison & Video
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Flat screen television picture freezes but not sound
Source box problem......nothing wrong with TV............T.
Feb 26, 2008 | RCA 32F531T 32" TV
Televison & Video Logo
2,936 people viewed this question
Top Televison & Video Experts
Electro Med Services...
