Question about Kenmore 62602 Electric Dryer
No Heat from Dryer
Runs but no heat, where do I find the thermal fuse unit and how to replace it???
    Sergeant:
    Champion:
  • 324 Answers
The thermal fuse is on the blower housing. usualy about 2 inches long white held on by 1 screw.
Posted on Oct 31, 2008
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
The dryer runs but doesnt heat. I pulled the heating element and took it to be replaced. The parts place ohm'd out the element and said it was fine. They sold me a small white fuse which i replaced but...
The skinny white fuse blows and the dryer won't run at all.
The small limit in this kit is most likely gone out.
That limit right there to the right of my hand is the problem most likely.
Service manual and more is HERE
Feb 03, 2011 | Roper REX4634KQ Electric Dryer
Dryer runs but does not heat. Replaced the fuse, thermostat, and the heating element. Still runs but no heat. If you ground the top blade on the thermostat. The dryer will start to heat
you need to check and make sure that you have enough power to the unit.
if you can check the continuity on all the thermal fuses and find one that does not have any continuity then it needs to be replaced.
Dec 24, 2010 | Kenmore 62602 Electric Dryer
Dryer won't heat...replaced heating unit...and still no heat...dryer is eletric...dryer still runs...just no heat
Visually inspect the heating element, burner operation, ignitor, thermal fuse.
Make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Good Luck and have a nice dayRating the solution is highly appreciated
Jun 29, 2010 | Roper RES7646KQ Electric Dryer
It runs but won't heat up.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Maytag Dryers
Kenmore dryer no heat
check the thermal fuse to see if it's open which means blown(no continuity through it). check to see if heat element is broken somewhere. And if thermal fuse is blown then you'll also have to replace the thermostat switch and the high limit thermostat switch(located close to heat element).
Apr 05, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Runs but no heat
i have replaced TH2 in my dle0322 about 6 times now. It never lasts more than a month. What could be causing this?
Apr 21, 2008 | LG DLE2532W Electric Dryer
Kenmore 62602 Electric Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
