Question about Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150
How to replace battery for Ademco 6148 - Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150
3 Suggested Answers
  • 20 Answers
SOURCE: How do I program zonig
The 6148 keypad is a fixed english keypad. It is possible to program your system from a fixed english keypad, but it is very difficult. an alpha keypad shows text descriptions of the programming fields. The model number is 6160. If you are doing your own programming, I would suggest replacing the 6148.
When programming, you're programming your alarm panel, not the keypad. The keypad is just an interface to the panel. If you have a tan box in your basement or a closet, that is your panel. There will be a sticker on the inside of the door of the panel that will tell you the model of the panel at the bottom. It will say Ademco Vista 10, 15, 15P, 20, or 20P.
From there you can go to the link below and find the installation and programming manual for your panel.
http://panelguides.com/panel-guides?task=viewcategory&catid=521
Hope this helps.
Posted on Mar 19, 2011
  • 78 Answers
SOURCE: why FC show on ademco
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Posted on Apr 23, 2011
Battery in ademco 998pi
It could possible be your main battery in the panel.
Apr 11, 2014 | Honeywell 998pi 998 Motion Detectors Pet...
How do I change the battery for alarm keypad?
Most keypads are using a 4 wire conductor coming from the security panel. If you have a wireless keypad such as a 5828 should be 3 to 4 AA batteries and as simple as removing the screws from the access panel in the back.
Sep 12, 2013 | Honeywell 6148 - Ademco Fixed English...
How to get rid of FC on keyboard
FC is failure to communicate, to clear the keypad you need to get a signal to the central station where your being monitored, it will clear when the receiver acknowledges the signal
Mar 25, 2012 | Ademco 10) Ademco 6148 Keypad Fixed...
How do I program zonig for my Ademco 6148 pad
Hope this helps.
Mar 18, 2011 | Ademco 10) Ademco 6148 Keypad Fixed...
How to reset ademco after chanhing battery
You have to run a system test. enter your code then press 5. If that does not work try entering your code then press 5 then 0. it all depends on system type. let system test run for about 2-5 minutes it sould reset. Ademco 6150 6150pl3 6150pl2 these identify your keypad model not system type.check your control box to identify your panel. Sould be like Ademco vista 10, 20, 20p
Feb 18, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Why FC show on ademco 6148 keypad,
Dec 07, 2010 | Ademco 10) Ademco 6148 Keypad Fixed...
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150 Logo
155 people viewed this question
Top Ademco Home Security Experts
Sean
Roy McCracken
M.A Cardoso...
M.A Cardoso...
Level 1 Expert
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
