Question about GE Kitchen Ranges
GE Gas Range Model JGBP33WEH3WW oven will not igniate. Bought replace part how do I install it.
Oven will not heat up. Glo plug does not light.
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Gas Range
See if the oven safety valve is OPEN if it is then you won't get the ignitor glow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 15, 2009
SOURCE: DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Posted on Aug 10, 2009
  • 89 Answers
SOURCE: GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Posted on Aug 28, 2009
Ge model jb400d oven will not heat up
Troubleshooting Why Your Gas Oven Won't Ignite or Heat ...
? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
Gas Oven Won't Heat - How to Repair (Part 1 of 2 ... - YouTube
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
GE, Hotpoint & RCA - Wall Oven Diagnostic - Not heating ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Dec 30, 2015 | GE Kitchen Ranges
GE gas range JGBP33WEH3WW totally dead after self clean
There may be an oven over temp thermal switch that has opened and needs to be replaced. Also you need to determine why the temp got so hot to cause this safety device to do its job. This might be a failed cooling fan
Nov 17, 2013 | GE JGBP33 Gas Kitchen Range
I have a GE Profile Gas Range model 317B6034. The top / range works fine, but the actual oven will not turn on at all. I don't smell gas nor is there any sound when I turn the oven on. Basically,...
It sounds like you have a bad ignitor in the oven. Hope this helps get you going in the right direction.When you turn on the oven the ignitor should glo.
May 16, 2011 | Ovens
Glo plug in oven does not work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 13, 2011 | General Electric JGBP33DEM Gas Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
Oven won't light GE floor range profile model
heatman101
hgdhgd
Dec 19, 2009 | GE Profile JGS968 Gas Kitchen Range
May 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not light. Ignition element will not even turn on
I have a magic chef gas range and the top of the stove burners work , the broiler works but not the oven..I think it is the glo bar. How the heck do I change this? It is a magic chef proven cooking performance from model # 8114p627-60 from about 1999
Jul 15, 2007 | GE EGR3000 Gas Kitchen Range
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
