Question about Vizio VX32L Television
Red pixels on white images on screen
Hi The screen will have red moving pixels on white and light colored images. the factory tech had me unplug for 5 min then enter menue and reset all settings which did not help. Any ideas? Thanks
  • Vizio Master
  • 5,568 Answers
This sounds like the digital equivalent of 'snow,' a random noise that can come from poor signal quality or poor or not firmly attached cables. I'd try exchanging the cable that is now in place from whatever signal source you have (cable/cable box, satellite receiver, etc.) with another either new or temporarily borrowed one from another device.
If this doesn't help, consider the other modern devices you have in your home such as light dimmers, fluorescent bulbs, digital clocks, home theatre equipment, etc. Pull the plug on any of those, one at a time and observe the TV to see if any of them are affecting it. Those named items are common sources of high frequency noise that can contribute to the kind of problem you are having. They have gotten better but can still produce unwanted sources of interference signals.
Posted on Oct 25, 2008
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
White dots on screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screen. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 27, 2010 | Samsung HLS4266 TV
Little green and white boxes on the screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Found it right here http://www.discount-merchant.com/MITSUBISHI-RMD62-939P977A20-Light-Engine-p/1138084.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
FAINT VERTICAL PIN STRIPES MOVINGS TO FULL AREA OF SCREEN
Apr 16, 2010 | Samsung HLN567W 56" Rear Projection HDTV
White vertical lines
Apr 14, 2010 | Toshiba 42H81 42" Rear Projection...
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Discolored Sides
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Ths if your tv is a dlp if its a Lcd it will be an issue with your light engine: Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Mar 29, 2010 | Televison & Video
The colors seem to be overlapping the red is further off than the other two
Hi, you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.The other thing that it could be is the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Mar 24, 2010 | Samsung HLN5065W 50" Rear Projection...
Pixeled picture, Red color, blurry and smeared images
Ghost image and snowy colorful pixelation with vertical black bars? You can try a hard reset by unplugging the unit completely for 4 hours. However you may have a prob with the YSUS and the YBU-L (YBuffer Upper-Lower.) Perhaps even the Logic Main may be defective. If you are still under warranty take it to a service center ASAP. If not Get out your Voltometer. You can email me for some help...
gysgt2u1@yahoo
May 08, 2009 | Philips Televison & Video
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
Vizio VX32L Television Logo
268 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
