Question about Canon PIXMA Office Equipment & Supplies
E,0,3 what will i do if it shows in the led "e,0,3".. but their is no paper jammed or any alien object on it...
  • Dennis Chowogna
    Dennis Chowogna Feb 18, 2012
    i do that many times but it didn't work.. :(
  • 684 Answers
Just Try To Remove the Cartridge Clean it and Reinsert it again.
Good Luck!!!!!
Posted on Feb 16, 2012
flopez
  • 161 Answers
SOURCE: Dell 1600 paper jam 1 or no cartridge
Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
Posted on Oct 02, 2007
SOURCE: Brother HL-2040 Flashing Paper LED
Clean the drum cartridge
Posted on Feb 19, 2008
SOURCE: error-paper jam
an english grammar check woud help
Posted on May 26, 2008
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
  • 1570 Answers
SOURCE: LED displays "0-E-3-0-E-3-"etc How to clear
Please try this
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
Also, if still not working, set up again the printer and set it as default printer. and try printing again
Posted on Feb 27, 2011
How to disassemble a Kodak ESP C110 printer?
Hello Edward,
There really is no reason to take it apart fully as the printer is showing classic signs of a paper jam. Usually it is a small piece of paper that has torn off and is lodged in the printer's paper path, it also could be something small such as a paper clip. Yours obviously is located on the side that the crease appears. The paper feeds in and then it hits the stuck object, then jams. Look very carefully at the leading edge of the paper near the crease and it may show the exact location of the foreign object. in the paper path. Remove the object and you should be all set!
Good Luck!
Rich Lilja
Mar 01, 2015 | Kodak Office Equipment & Supplies
My paper had a paper jam because an object was stuck on it. After removing the object the printer still indicates E3 or paper jam. What do I do?
clean it easy with cleaner and check it proper if cut pieces in roller so that error regular show you open the casing and check it properly
Sep 25, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My lexmark interpret S405 is showing the message "paper jam" and this is recurring. I remove the paper turned off the printer then turned on, it again shows the message paper jam when there is no...
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
I have a P915 printer that even though there is paper loaded and no paper jam the paper won't feed. It will start to run and the message "add paper" appears. It appears the "feeder...
There could be some sort of foreign objects that fell into the paper feed system. Remove the sheets of paper from the printer. Grab a flashlight and look into the feeder for any debris. If you are capable and willing, you may carefully turn the printer upside down so any foreign objects will just freely roll out from the feeder.
Re-seating your cartridges may also help resolve the problem. Remove and properly reinsert your cartridges in the cartridge carrier. Turn off/on your printer to reset it.
Apr 15, 2011 | Lexmark P915 InkJet Photo Printer
DISPLAY SHOWS "PAPER JAMMED "READING
I think it still have maybe a very small paper jammed.
Tries dismount the more you can from printer, since I'm almost sure it stills remains maybe a very small paper...
Apr 14, 2011 | Canon PIXMA MX300 All-in-One Printer
...Still "paper jam". I did
This article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on the Lexmark P4350/P4330 Photo All-In-One will help you fix the paper jam problem. However, if problem continues, there could be some sort of foreign objects that fell into the paper feed system. Grab a flashlight and look into the feeder for any foreign objects that's in the paper path or, if you are capable and willing, carefully lift your printer upside down so the foreign object will freely roll out from the feeder.
Apr 03, 2011 | Lexmark P4350 All-In-One InkJet Printer
Canon pixma mx340 4-in-1 wireless printer thinks it's jammed when it's not. say "error 6000". Assistance is greatly appreciated. thank you
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Oct 31, 2010 | Canon PIXMA MX340 Wireless Office...
Erroneous paper jam message. Unit sat without paper or cartridge for 3 months. When it was plugged back in without paper, the paper jam error shows up.
it seems that the head cannot move from its initial position to the paper margin position. check for any objects in the paper path. Put a paper (not more than 220 gsm) in the paper tray and press eject button. Push paper to go inside the printer. It will come out with the paper or object in the path. If it did not give solution call the service call centre.
Aug 14, 2010 | Epson PictureMate (C11C556001) InkJet...
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
old marine
old marine
