Question about Dell Computers & Internet
Dell Dim C521 power button remains orange; doesn't boot
  • 669 Answers
Take a look at this document from Dell. You should have some diag lights on the front of the computer, and this should help you find what is not passing post.
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
Posted on Feb 15, 2012
3 Suggested Answers
  • 121 Answers
SOURCE: disk drive not found
It sounds like the hard drive went bad. Can you see the hard drive in the bios at all? When you try and boot the computer does it say drive not found? Try booting from the vista cd and see if you can start a new installation. If you can do the intallation the drive is ok. If not the hard drive is bad.
Posted on Jun 24, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: have emachines T5048.. boots up but shuts off
Sounds like you've tried everything but the motherboard, so I'd have to say that's where trouble is. You can find replacement motherboards online if you want to stay with the original board. If you do that, you won't have to reinstall Windows because the hardware will be the same, but it's a costly part.
You can buy any micro-ATX motherboard which takes the same processor and use that as a replacement. This gives you a wide choice of replacements at reasonable prices, but you'll almost certainly need to reinstall a fresh copy of WIndows and activate it since you won't be able to use the factory restore image. This isn't a bad thing, though, since you wind up with a system free of the stuff that typically comes preloaded, and is usually worthless.
Posted on Mar 12, 2010
C521, get the orange light, fan turns on and it's just steadily orange light
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Oct 27, 2012 | Dell Dimension C521 PC Desktop
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
My dell dimension c521 does not boot and shows a amber light. This happen after I cleaned it to change the processor.
2 reasons, one the cpu isn't supported by the board or the power supply isn't great enough. I'd go for option 1.
Apr 07, 2011 | Dell Dimension C521 PC Desktop
Dell C521 Power Issue
I would replace the power supply and if that does not help (after battery replacement and power supply), the ram could be faulty but usually faulty ram will beep a code. If ram has no avail i would suspect the mainboard and replace. Good Luck
Nov 24, 2009 | Dell Dimension C521 PC Desktop
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
Computers & Internet Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
