Question about Carrier IBM UNIT 2380 79F4796 Drive Case
A.C. unit I have an A.C. unit. Model# FA4ANF030. The problem is that my air conditioner drips alot of water. The dripping starts from inside the A.C. unit like if its not freezing the way its suppose to. I Can also set the temperture. For Ex: to 70 degrees and it only goes down to 80 degrees it never reaches the temperture I set it on. I've cleaned the A.C. unit. I cleaned my A.C. unit outside also. I've had a technician come and put freon, but apparently that didn,t work. I'll be waiting for your response. Thank You
  • bduke Dec 19, 2007
    I have two of these units in my house and they both leak. The coil is mounted at an angle and the condensation is supposed to sheet flow down into a catch tray. Instead, it free drops down below into the return air duct. When the unit is running regularly, it will accumulate 1-2 gallons before it then starts spilling over onto my floors. Two service reps mentioned a drip eliminator product, however, I haven't been able to track these down. Any suggestions?
Just call up aircon people
Posted on Oct 25, 2008
I am still asking how to put freon in my air conditioner myself
Posted on Jun 10, 2008
  • 236 Answers
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Posted on Jan 02, 2008
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
My window unit air conditioner unit is dripping profusely out of the bottom of the unit inside of my apartment. the drip pan is overflowing.
Jun 04, 2011 | Frigidaire Heating & Cooling
Our air conditioner starts dripping water inside the unit inside the house.
water dripping is to be expected, dont worry about it. But it sounds like its not tipped to the outside enough. Also check inside under the cover, if leaves and debris get stuck in there it will change the direction of the water flow.
Mar 04, 2011 | Coleman Heating & Cooling
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Computers & Internet Logo
953 people viewed this question
Top Carrier Computers & Internet Experts
Marvin
Marvin
Paul Carew
 steve
steve
Are you a Carrier Computer and Internet Expert? Answer questions, earn points and help others
