Question about Brother XL-2600I
Needle hitting bobin case and case is loose. How do i fix it?
  • rachel beslin Feb 15, 2012
    bobin also flew out of machine while it was completly together.
  • Brother Master
  • 7,365 Answers
Sounds like you need a new bobbin case
try a new needle & if it still hits the bobbin case the machine could be out of time
& would have to be retimed at a sewing machine repair shop
Posted on Apr 04, 2012
2 Suggested Answers
  • 1456 Answers
SOURCE: the needle is hiting bobin
Hello
Make sure the needle is fitted properly and that the needle clamp is not loose. Bent or blunt needles will also cause needle breakage. If everything else is OK, make sure you have the right size needle for the thickness of the fabric. Using the wrong presser foot for different types of stitches will also cause needle breakage. Check the owner's manual or the computer screen readout to make sure you have the proper presser foot for the stitch you have programmed in.
Other causes include scratches around the hole in the needle plate, pulling the fabric too tight, a scratched bobbin case and the wrong bobbin type for the machine.
Choose the correct sized thread and needle for the fabric in question. Re-thread the machine by passing the thread through the needle bar. Hold the thread with both hands and fully pass it through the hook.
Posted on Nov 06, 2010
Needle hits and breaks, when I take bobin and carriage out the needle still hits. Ha ow can I adjust the timing? Brother CS 6000 i
Make sure you are using the correct needle for your machine! Also check your manual to make sure you are inserting it properly. Some needles are rounded on one side and flat on the other. If you use the incorrect needle it will hit or insert it incorrectly it will also hit and break. June
Jan 26, 2015 | Brother CS6000i Computerized Sewing...
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
I volunteer at a women's prison in their sewing class and we have model 385-16231301. The bobbin thread does not pick up. The bobin case seems to sit in their properly, but when I turn it manually...
check the needle to make sure that it's inserted correctly, the flat side of the needle goes to the back of the machine,, and make sure the needle goes all the way up into the needle cavity .
make sure the bobbin is correctly inserted
clean under the needle plate area & in bobbin area for loose threads or lint
if none of the above work & the needle is still hitting something then it 's a great possibility it's out of time & needs to be serviced, cause the needle should not be hitting anything when it goes down.
Aug 26, 2011 | Kenmore Sewing Machines
Pfaff creative 2134.....needle is hitting the bobbin casing
There is two possible solutions. either the machine has been knocked out of time by a thread jam or the needle rod has been bent. Good Luck!
Apr 19, 2011 | PfaFF Sewing Machines
The top thread is looping every 30 or 40 stitches on my Juki DDL 8700. I put in a fresh needle, cleaned thoroughly, fresh throat plate and re-threaded. Any ideas? Thank you!
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
Thread is knotting up under the feed dog plate getting error LO.I tried removing the plateand cleaning and replaced bobbinholder and it is still jamming. is there supposed to be any play in the bobin...
It should move a little so the thread has clearence. If the thread is bunching underneath, it usually means the thread's not in the take-up lever or top tension is too loose. If you're needle has hit the bobbin case and created needle marks, the thread can get caught... in which you'd need to replaced the bobbin case.
Feb 23, 2010 | Janome 8080 Computerized Sewing Machine
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Needle is hitting the bottom of the bobin hausing
It sounds for sure like the needle is not in all the way. Try inserting the needle again, it ,may have slipped when it jammed.
Mar 17, 2009 | Sewing Machines
My Singer 2639 Bobbin case pops up out of position after few stitches and needle hits case, Singer says it needs retiming and take it to repair. I cannot continue paying repair as this happens too often.
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Sep 03, 2008 | Singer 7462 Mechanical Sewing Machine
Brother XL-2600I Logo
109 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
