Question about Whirlpool RBD245PDS Electric Double Oven
Need manual for Whirlpool accu bake double oven
Oven model RDB245PDB12
  • 491 Answers
SOURCE: whirlpool double oven. fan assisted oven is not heating up fan is
NEEDS A NEW HEATING ELEMENT
Posted on Jul 18, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
barkencoa
  • 3463 Answers
SOURCE: Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Posted on Mar 12, 2010
fixyourboard
  • 310 Answers
SOURCE: My Whirlpool gold double oven displays the code
F2 E3: Key held down too long or key is shorted.
Check keypad connector for firm connection. Press Cancel, if error returns after 60s replace keypad.
Posted on Jun 28, 2010
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
I have a double elec. whirlpool self cleaning oven with accu bake system It will not turn on at all. everything is just off.
This is often due to a control board failure. The board may be NLA (no longer available). It can be rebuilt with a 2 yr warranty. See: http://www.fixyourboard.com/boards/4448876.html
Aug 29, 2015 | Whirlpool GBD307PD Electric Double Oven
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
I have an error code of E6 and F2 on my whirlpool accu-bake oven display panel. What do they mean.
Hi
F2-E6 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Ovens
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
ACCU BAKE codes come up e6 f2
You have the following error.
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
My oven was a display model & I have no manual. I'm trying to figure out if I can do some type of delay bake
Here's the manufacturer's website for a free downloadable manual. Don't be thrown off by the whirlpool name - this will have your Maytag manual. Enjoy your new oven and send me a brownie when you bake the first batch!
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CWE5800A&siteCd=MT_EN_US
Dec 24, 2008 | Maytag CWE5800A Electric Double Oven
Whirlpool RBD245PDS Electric Double Oven Logo
71 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
