Question about Ricoh FAX5000L Plain Paper Laser
Network Error 12-10 - Ricoh FAX5000L Plain Paper Laser
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Jul 05, 2015 | Casio FX-9750GII Graphing Calculator
How to replace horns
if you could see it just remove your battery negative cable and i think its a 12,10 mill,socket you would need then unplug the wire and remove the old horns and replace them
Nov 21, 2013 | 2004 Toyota RAV4
My psp-go it saying Error 80550F17 at my playstation network
This error message means that the Playstation Network is currently unavailable.
It is usually a temporary error and the store will be available again shortly (within a few hours).
Sony has a twitter account for status updates:
http://twitter.com/AskPlayStation
Apparently the PSN network is currently down:
"The PlayStation Network will be down for maintenance approx 8am-7pm PST Wednesday 03/09/2011. We apologize for the inconvenience."
Please rate my answer.
Many thanks,
Chris
Mar 09, 2011 | SMC USB 10/100 Ethernet PS2 Network...
Error code list fo geforce 9300 motherboard. i have error code 85 right now
You seem to have a problem restoring a network mapping connection to a shared folder. System error code 85 means "The local device name is already in use." This error code may also display as "ERROR_ALREADY_ASSIGNED" or as the value 0x55.
You may receive the "The local device name is already in use" error message when you try to restore a network mapping connection to a shared network folder on a Windows XP-based client.
To resolve this issue, remove the existing network mapping. Then create a new network mapping for the share. Your anti-virus program could also be part of the program. Try disabling the AV while you create the new network share. Hope this helps.
Use this link as a reference http://support.microsoft.com/kb/890413
Apr 03, 2010 | Computers & Internet
I have an HP 5500dtn Color Printer and I am receiving an 81.018 EIO Error, what is this?
From the HP Service Manual
DEFECTIVE NETWORK Card, OR Formatter Board
bullet_red.gifUnplug network Cable or Parallel Cable from the printer and then turn it off and then on, if error goes away then it was a bad communication from the network or the computer
This usually solves this error.
bullet_red.gifIf error persists while printer is disconnected from the network or computer, replace the EIO/Network Card and or the Formatter Board
Nov 24, 2009 | HP LaserJet 5500dtn Color Printer
Samsung printer error ssg_thnk-32 diag error
There might be a firmware update on the printer, try that. Also did you try another network cable? Sometimes they go bad.
Apr 18, 2009 | Samsung SCX-4300 Monochrome Laser...
Error:Starting Network 363: can't open/etc/dhcpc/dhcpcd-eth0.info
Have you tried to reload the software for the Network Adapter? If not! Have it first.
Mar 09, 2009 | Dell Ethernet Card Network Adapter
Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
Ricoh FAX5000L Plain Paper Laser Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
