Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ squeeking
I believe it's the drum bearing but I'm struggling w/ how to get to it. Can't seem to find any diagrams online. Thanks!
  • 147 Answers
Go to this web site. i find it very handy
Posted on Nov 02, 2008
NBXR453EVOWW dryer squeeks
The rear drum bearings could be going out, and believe it not, on some rare occasions the motor itself could make a chirping sound.
Jun 21, 2012 | Hotpoint Dryers
Squeaks from drum area during operation
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a frigidaire LEQ2152ES0 Front Loading Dryer. The machine has started to squeek rather loudly. I've noticed a
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link:
Thank You for using fixya
Mar 14, 2012 | Frigidaire GLTF1670A Front Load Washer
Squeeky dryer
if the squeeks are coming from the tub while turning. it may be the front tub glides. but the dryer will need to come a part to fix them. good-day ! more possible symtoms-- Damaged Drum Wheels, Deteriorating Drum Bearing, Failing Idler Pulley Wheel, Loose Belt.
Mar 08, 2012 | Frigidaire Dryers
Dryer still squeeking after I replaced the drum bearing
more than likely tensioning pulley on the drive belt, lubricate with bearing grease or replace if badly worn.
Oct 25, 2010 | Frigidaire FEQ332E Electric Dryer
When my dryer is running i hear a loud metal on metal squeeking, like something (coin perhaps) caught between the drum and the frame. how do i open it up to check?
Your drum bearing has woren off. You take the dryer off from the front. Take the tension of the belt, and replace the drum bearing.
Nov 24, 2009 | Frigidaire Dryers
The dryer drum squeeks.
Replace rear bearing with kit available, and replace front glides
Dec 18, 2008 | Frigidaire GLER331A Electric Dryer
Dryer just started squeeking.Model GE dwsr405eboww. How do I find the problem get off the back or the front off to get in there.. Thanks
More than likely you have a drum retainer bearing going out. This is a mechanism that is comprised of two parts. On the interior of the back panel of the dryer there is a small mechanism that looks like a C on it back. This is where the bearing attached to the center of the rear of the drum slips into to keep the drum level. I have found that the portion attached to the dryer wall usually is at fault in these cases. I am noy familiar with the exact make up of your model but a diagram for the model is easily found online.
Hope this helps you out.
Sep 03, 2008 | Dryers
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
115 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
