Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman 5000 w generator
I was wondering if i could remove the generator from the motor and use the generator for a wind turbine i m building what s your thoughts Thanks
  • 169 Answers
1) You'd have to figure out a way to support the engine end of the rotor. Right now the engine rear main bearing is the front bearing of the generator.
2) You'd need to make a wind turbine that produces 6+ horsepower (at least) to get the 5 Kw out of it.
Usually small wind turbines drive polyphase generators that charge batteries used to run inverters. Go see: http://www.otherpower.com/otherpower_wind.html for a pretty good discussion of the problems to solve.
Posted on Nov 29, 2008
I have a Coleman Pro-Gen 5000 with a Briggs and Stratton motor in it, I was wondering what kind of oil to use in it and what size sparkplugs I need
30W OIL, take old plug to store customer service will match. Parts: http://www.ereplacementparts.com/powermate-generator-parts-c-117046_130613.html?gclid=COe1kb_yi80CFZGJaQodXvYMXg Info: look on valve cover "DOHC" marked. On the side is the model number for the engine. Search on that model number for engine parts.
Jun 02, 2016 | Coleman Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How do you remove the start stop switch mounted on the rope pull housing on the coleman 5000 powermate 7500 watt unit. You can't get the housing off without removing the start stop switch.
without seeing it, they usual have enough lead length to allow the cover to be moved so you can get to the wire, The switch usually has a blade with a slide connector that can be removed.
Oct 12, 2014 | Coleman Powermate 5000 Generator
How to seperate generator from motor coleman 5000 ?
undo the bolts between alternator and motor ,remove motor from frame first.
Aug 10, 2014 | Coleman Electrical Supplies
Can I buy wind turbine generators on Amazon?
You can buy wind turbine generators from Amazon here:
http://www.amazon.com/s/ref=nb_sb_sabc?url=search-alias%3Daps&pageMinusResults=1&suo=1367394691758#/ref=nb_sb_ss_i_0_14?url=search-alias%3Daps&field-keywords=wind%20turbine%20generator&sprefix=wind+turbine+g%2Caps%2C256&rh=i%3Aaps%2Ck%3Awind%20turbine%20generator&sepatfbtf=true&tc=1367394695955
May 01, 2013 | Renewable Energy
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Feb 01, 2010 | Coleman Powermate Powermate 5000W...
AVR board is burnt out
AVR burn out is the most popular problem with electricity supplyment....
replace the AVR...if it burnt out shortly after words..then u have a problem with the rpm of the engine...if not..then its just a AVR burnout..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Sep 27, 2009 | Coleman Powermate Powermate 5000W...
Wind turbine plans/solar panel plans
You are in for a lot of fun and money saving tips and instruction. I as you am interested in building a wind turbine/ generator to do my part in saving the environment and saving me money. I have a small work -shop and have some generator parts to work with. Reading about building is fun but watching a video of actual working machines is the most. Go to www.youtube.com and enter homemade wind generator in the search box and enjoy the fun and instruction. Good luck with you project.
Jan 30, 2009 | Electrical Supplies
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
185 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
