Question about Zebra S600 Label Printer
How to find ip address on zebra s600 - Zebra S600 Label Printer
Joed911
  • 4338 Answers
SOURCE: Need Zebra Stripe S600 Printer Driver
Find the driver at this site:
http://www.howtodrivers.com/model17586.html
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
SpideRaY
  • 687 Answers
SOURCE: How do you set a static IP address on the Zebra
If this is a wireless printer then all you need to do is set an address reservation on your router and then set up a fixed IP port on your printer driver.
First: Install the printer driver as a normal USB printer by connecting the cable during the install process dont use the wizard if you can help it.
Second : Find your MAC address for the printer (all types of Network Cards MUST have one) this will either be in the LCD control panel or on the bottom of the printer on a label and set this in your admin panel of your router to say 192.168.0.10 for example. You can normally enter this using 192.168.0.1 but all routers are different. Check here for your make and model http://www.routerpasswords.com/
Last : Goto the printer driver properties for the USB printer you have just install click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install.
Thats is. !!!
Posted on Nov 30, 2009
  • 31 Answers
SOURCE: how do i find the IP address on a Zebra Z4MPlus?
If you can not see it in the LCD menu on the front panel, you can find it by printing the IP info on a label. There is a reset button near the Ethernet jack that will let you reset the print server settings or allow you to print a config label. Load up some media, power the printer on. Once the printer is fully booted, use a paper clip or the like to press the button once. A label will print that details the IP settings. Once you have the IP settings, you can log into the printers web interface by typing the IP address in your browsers URL bar. Do get a copy of the manual.
Posted on Jan 30, 2010
  • 4234 Answers
SOURCE: what is the defult ip address for the zebra
When received or when a reset is performed, the default IP address is: 10.3.4.102. The best way to confirm this is to force the printing of a configuration label. Look at the configuration label that is printed. That will contain the "current" IP assigned to the printer. You can download the manuals for this from the Zebra web site using the model number to get to the printer specific page. Choose the download tab.
Dan
Posted on May 27, 2010
Zebra s600 prints on label and feeds 3 blanks
it must be wrong label configuration or problem with gap sensor.
You can follow this step by step zebra designer ;
Zebra Designer Kurulumu ve Kullanm Teknik Barkod Etiket
Jul 02, 2014 | Zebra Stripe S600 Thermal Label Printer
We recently changed high speed networks and our IP address changed. Since the change our zebra 2844 printers are not working. Is there a way to change the ip address for these printers? If so how.
Turn the printer off.
Disconnect the power-cord.
Reconnect the power-cord.
Turn the printer on.
It should automatically reconfigure itself, and get a "new" IP-address.
Then, you'll have to "delete" that "networked-printer" from your computer,
and then reinstall that "networked-printer", so that your computer can "talk"
to the printer at its "new" IP-address.
May 12, 2011 | Zebra Eltron TLP 2844 Thermal Label...
What is the defult ip address for the zebra tlp2844?
Dan
May 25, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
May 18, 2010 | Zebra Stripe S600 Thermal Label Printer
How to put the paper roll in Zebra V600 stripe printer
Send me your email address. I can send you the directions.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
3821 w. 127th place
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 29, 2009 | Zebra Stripe S600 Thermal Label Printer
Thanks, Joe
Nov 15, 2008 | Zebra Stripe S600 Thermal Label Printer
Unable to reach the device for a statics IP address fro this Zebra TLP 2844-Z printer
I work for zebra. you should user zebra net bridge, its the current network tool and the best to use
Aug 01, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
ZEBRA S600 MAINBOARD
the parts manual says 45763-001M.
May 06, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Label Printer Logo
446 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
