Question about Frigidaire Kitchen Ranges
My fgf337asj gas stove, the oven will not light. New igniter and valve installed.
I installed an new igniter and gas valve. Nothing is working.
aborcass
  • 2651 Answers
SOURCE: Magic Chef freestanding gas oven/stove
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Posted on Mar 17, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Oven will not light Model SF385PEE Help its Turkey time
i would check the wiring tothe gas valve, sounds as if you wired incorrectly
Posted on Nov 23, 2008
SOURCE: SEARS GAS STOVE MODEL#79072114100.OVEN WONT
i had the same problem ( ignitor glows but no gas) on sears model
79071012300. i replaced the ignitor (glow bar) and the oven lit within 10-15 seconds! it was easy to replace and it took longer to figure out how to get the broiler drawer out of my way than it took to replace the ignitor.
Posted on Dec 06, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
MNTECH
  • 1543 Answers
SOURCE: brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
Posted on Apr 29, 2009
Gas oven will not light or open valve, Brand new ignitor
The igniter will not glow unless the gas valve is operational. The gas valve will not open unless there is power to supply the igniter. Igniters have a low resitance (20-100ohm). So, you can test it. Normally there is no power going to the ingniter.
You may have a defective gas valve (usually the safety circuit). The valves are not repairable (it would be dangerous to attempt it, and there are no parts available). So, you must replace the entire unit.
The thermostat may be shorted. If that's the case, the valve thinks the oven has reached temperature, so it doesn't need more heat, so the igniter won't glow, so the gas won't flow.
Jan 20, 2014 | GE Profile JGBP79 Gas Kitchen Range
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
The top burners all work fine. When I turn on the oven, there is no smell of gas, or anything. Any suggestions? the stove top burners are working well but the oven is not generating any heat although the...
IF THIS IS A NEW STOVE THERE IS A VALVE IF YOU PULL OUT THE LOWER DRAWER AND LOOK WITH A FLASH LIGHT YOU WILL SEE A VALVE AT THE REAR OF THE STOVEAT THE LOWER LEFT OF THE VALVE THERE IS A TINY LITTLE HANDLE WHICH OPENS THE GAS TO THE OVEN FLIP THE LITTLE LEVER SO IT IS IN THE OPEN POSSITION, THERE ARE NO MARKS SAYING OPEN OR CLOSED AND THE LEVER IS VERY HARD TO SEE
TRY THIS AND SEE IF THE OVEN STARTS WORKING
Aug 25, 2009 | Tappan TGF303BW Gas Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Gas oven will not ignite
I would be suspect of the temperature control valve based on your previous experience. I am assuming the safety valve you are speaking of was really a regulator.
Jan 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Nov 21, 2008 | Whirlpool SF325 Gas Kitchen Range
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
